Previous in Forum: What is Lean Manufacturing?   Next in Forum: Inconsistent Hydraulic Pressure
Speed and Feed Calculation for Dummies
09/13/2009 11:52 AM
I'm looking for an explaination of calculating speeds and feeds for a cnc vmc in the simplest terms possible. After seeing many tables of calculation I am absolutely confused. I am a set-up/operator of vertical mills and have thus far gotten by using educated guesses. However, I'm at the point in my career where "close enough" is no longer good enough. could someone PLEASE explain how this process works?
Re: speed and feed calculating for dummies?
09/13/2009 11:57 AM
There's info around this site:
End Mill and Cutting Tool Speed and Feed Calculations
I've never used anything but crank mills.
Good Luck.
09/13/2009 12:25 PM
Post 1 helps, Since you are a set-up operator, did you not pick anything up.
Working in the ship yard, do to conditions, we were cutting with High Speed but avoided coolant as much as possible because it had some effects to jigs, fixture and material. I started a database, to get reference results off of given parameters.
Now at a machine shop where you would be using coolant, this would not be as critical.
The first thing is define your tooling, and then to start as a base-line, calculate chip load.
But setting up a data-base with tooling, is a good idea. Materials Speeds and feeds that has a feed back with tolerances and finished results may not be a bad idea.
Re: Speed and Feed Calculation for Dummies
09/13/2009 8:59 PM
The basic information is the speed the cutting edge is going through the material. If a round cutter or a round part you calculate the outside diameter times pi to get the distance the cutting edge is traveling. A simple formula is: RPM = (3.8 x CS)/dia. RPM = Rev. per minute
CS = cutting speed in feet per minute or meters per minute.
dia. = diameter of cutter or work when turning
The cutting speed is selected by the type of material being cut, the type and material the cutter is made of, the type of cut being made and the stiffness of the machine and setup.
Example: Aluminum part solid in vise being cut with 1/2" carbide end mill
1) normal cutting speed range for aluminum with carbide is 200 to 1000 feet/min. This information is what is given by the cutter MFG. in charts and varies according to material, operation, and cutter.
2) vise is a solid clamping way to hold part
3) If machine is small bridgeport or low HP machine you could try 300 ft/min to start
This would be RPM =(3.8 x 300) / .500 = 2,280 RPM
This would be OK for roughing or finishing by varying the feed rate, depth and type of cut in the job if the machine and job does not vibrate to much.
NOTE: IF CUTTER IS A BALL NOSED END MILL AND YOU ARE CUTTING ON THE BALL TIP THE CUTTING SPEED IS MUCH slower THEN CUTTING ON THE OD OF THE CUTTER.
The FEED RATE is measured by how much is cut by each individual tooth of the cutter
and is know a the chip load per tooth. In the above example if the cutter was 2 flute cutter you would feed it appox. half as fast as a four flute cutter with the same chip load. On a solid carbide 1/2" cutter in aluminum you can feed it .001" (finish) to .007" roughing for each tooth (flute- cutting edge) 2.28" x 2 =4.56" / min finish feed rate for a two flute cutter. Or 31.92" / min roughing feed rate for a two flute cutter.
Your depth of cut is determined by how strong the sit-up and machine is and the power to drive the cutter.
NOTE: It is best to program for what you think will run but start the job running with the feed rate turned down to 10 or 20% to start and increase till you see what is safe to run the job at. Same thing for the speed, but crank up the speed before you crank up the feed. Good Luck
GOD'S BLESSINGS
Bill
Good Answers: 119
09/14/2009 8:52 AM
Go Here! Buy it!
I've been carrying mine around for 42 years, since I began my machinist apprenticeship.
Hooker
09/14/2009 5:23 PM
It's all about "Chip Loading ! "
09/14/2009 5:37 PM
Correct, it was brought that up in post #2 .
I have found that each machine is different, after operating a machine one will find each one has personality, no matter how noticeable whether from new on or acquire from wear and tear.
And doing high precision machining, that should take it in account.
Register to Reply 6 comments
Anonymous Poster (1); Hooker (1); lyn (1); Not too Smart (1); phoenix911 (2)
You might be interested in: Rolling Mills, Vibratory Tables
