I agree the idea is excellent one. This is what has been tried by NASA to construct a habitat with zero external feed through and was not very successful at small level. On earth we use only sun's energy as external input and rest is done locally. Do you think you can live without sun forever unless you create everything that sun does on earth.
In Theory also you need to inject similar parameter and look at what it needs finally to reach a goal to sustain withour sun on earth or for that matter anywhere else.
Thanks for your reply. I would like just to note that we don't know about action of all of the forms of energy from Sun. Maybe we could build something that interfere into its exchange with universe. We have in Ukraine one "mad" inventor, who writes that he has a success in that.
By the way, have you noted described in the article possibility to obtain part of the bind energy after action with special quality on some object, which will be destroyed by this?
By the way, I was graduated as a nuclear scientist and it looks interesting for me what is made up at your company. Also it could be interesting to get more info about your high voltage pulsers. They can be applied to test some ideas from the article. Could you give me a clue on what technology are they made, how big are they and what prices does your company have for them? Please, reply me to aliale@hmti.ac.by.
The first idea about the pulsers was that ones could be made using piezotransformers. However, I am not sure that ones can be so fast.
In extreme conditions one can build a system that can make people to survive for a while until they completely transformed into unusable system. To get back again, the system need to repair itself and in the process will kill whatever comes its way and then can regenarte itself.
Just because no one understand one's thoughts, you can not call one mad.
Right now I am not exporting these high voltage parts and are meant for research in India.
Which Institution or Organization you belong to? Your web site?
It is good that you are understanding the person who is badly named by people. I think this man understands God's basic theory and higher than any one else. It is not easy to code God's theory in mathematical equations solvable by man as God plans are much bigger. Even if you wish to code the sustaining power of the earth, partially only then also you will need supper computer and and a model to explain something you can see within life time. We can not even fully code our gene formations and its functions and what will be next in gene formation that will be next form of us. However it all is happening in the nature. Nature's basis function is highly extended from minus infinity to plus infinity and everything possible within it with something inbetween more stable than others that gets quantized in time and can be seen as images for a while and these patterns keep changing like the way images change in clouds. If you concentrate on any image in the coud then you may never ever see it again. That could also become of us but the system will remain active for ever and in different forms. As we see many things in alike forms, we get this idea that such things will also happen in time and system will get back to those situations once again. This you can call repair but in real sense it is only one of its state. If you think you are surviving and you are in same world or universe, then that is a serious mistake. It is never the same. It is not something that is inside the egg that is changing and universe is not with limits even though it may look like or we can assume for simplicity or because we have no ways to know about it. What makes possible or impossible is only thing we can look at. Hence your efferts to code the possibilities is valuable.
I build the HV switchers for Ion Beam applications. These are generally in 1kV to 100kV range and for fast pulsed high voltage conditions in 100ns rise time to slower versions. I also manufacture programmable delay and pulse with timers and charge amplifiers. I am not sure if you will need such things for your research. I do not want my technology to be moved out of the country to the place where international community does not want sensitive technology to reach. Money is not very important thing for me. Stability of the world is very important as I want people of the world to be happy and friendly. If you happens to actually need these then I may be able to give you these. Yes, I did read the journal of Engineering Physics.
I will like to have the actual name of the scientist, who's idea you are working on. Actually all tribal culturers are the basis simple model of this and they survived for thousands of years within their limited knowledge. Small habitat survive because they are self sufficient and only external intervention affect them. We are 9 reserve forests where such communities live undisturbed by others. We call them biospheres.
The man who wrote several books about new physics and energy sources received all this as a film on a wall of his house. Just he saw this film. Yet he could stay far away from psychiatric clinics and stays far away from ones even now. He also says that he could built new energy source. If you would like to read, his short presentation is on this link:
It has his story and thoughts on quiet good English.
What is related to the HV pulsers and relation of international community to my country - that is just a press to live like not all, but just the most aggressive countries live. "Live like we do". What they do say. "Otherwise we will treat you bad". Due to this we simply can conclude that these countries are really bad democracies, as what they actually do is against what they are appealing for. They do not give not only for us as a nation freedom of choice. Now we simply do not believe them. And we will live as we want, not as they want from us.
Also I would like to note for you, that there is no real nuclear research now in Belarus. Just conservation of nuclear materials under good security. After Chernobyl it's really not good to have even hypothetical possibility for nuclear pollution again.
I need these HV pulsers for my own ideas. I do not tell about them to anyone here and at my job too. By the way, the pulsers, if they are small and can give out enough power for a discharge, could be used here for a better combustion in the engines. Such a research is going on in our Institute.
The mentioned ideas from me belong to artificial intelligence, in general. As I can see on your site, you also work with robot's brain cards and so on. I have completely different approach. With this approach I can explain from what and how such films as the above mentioned man had received can come.
What is the voltage and current rating you need in the switch and time of switching. For engine firing you may have different ratings. Generally people use mechanical arrangements.
In some brain disorders one can see what one thinks. Hence, one can read anywhere as one is thinking and analyzing something. There is no real writing on the wall but it is percieved by the person as if it is there very clear. There are large number of such people on earth and some can be intelligent enough to see great Physics on the walls.
We all dream and it comes from inside and only we differ that we do not see on the wall. With intense thinking you can feel it almost real. This can be achieved by anyone in the state of meditation. However some men can have this ability of reading on the wall without any special efferts.
Yes, I had interest in mind and consciousness long ago when along with Lee and Ron Blue we were involved in discussion on their Core Theory, which is Quantum memory in matter rather than inside computers. This was almost 15 years ago. I know, how to build quantum memories and can make the robot better than men in many respects. However, it is not a goal for my life now.
You can go ahead with what you feel good for yourself. AI is a good field to work. It is getting embedded almost every software now.
We used to get some tractors from your country or with that name. Those used to be high power too high for Indians.
I didn't mention engine firing. They use special discharge regimes to ionize fuel before injection into the combustion cameras. The tractors have name of our land - Belarus. Now they are not so heavy and powerful. The plant extended line of models.
What is related to mind and consciousness,
I do not think that memory and real intelligence are located inside our brains and even inside matter in quantum bits. Both are in motion and intensive dynamics outside in the scale of the whole universe. And both are touching something beyond.
As name of your firm relates to sensors, you can be in principle interested in building of such a sensor system, which will reveal much better than now what is inside our bodies or inside different objects without X-rays, NMR and so on. I wrote a paper on that subject and now I am thinking how to make such a system with possibility to interfere into this very fast motion of energy out to universe and back from something which might be a research object in a clinics or laboratory.
Recently I have received some progress in motion to practical things related to such an idea. Part of this motion is related to the ways to build new energy sources. That is a reason of questions about your HV pulsers.
It gives clear description of the main idea about location of memory and intelligence. It also give some clues how to test the main idea of this approach.
I am looking forward to your comments.
By the way, one of my mostly loved books is AranjakaParva from Great Mahabharata. You should know these words. Is my English spelling of these words right?
Accilent thinking. This article "New Devices and
Approaches for Medical Imaging" by
Prof. (Dr.) A.Yu. Alevanau is just great. It may be hard for us to believe but it looks to me a reality. There are few such people in India who believe in similat lines but something in this article was just great and different.
Thanks for sending this.
What is that you wish to achieve from HV pulser. Something like a streak camera to capture very fast image signature? What is the Flash time you want to achieve and what is the media that you wish to ionize? Ionizaation potential, pulse duration and pulse current are three important parameters.
Thanks for your reply. I appreciate it very much. Unfortunately, I am not professor or Dr.
Just a researcher on the PhD position having only MS degree in Physics. It was difficult financial times here and I wasn't enough lucky to take part in such a PhD program, which had enough resources to be completed.
Anyway, thanks for your evaluation of the ideas in the article.
What is related to the practical things with HV pulsers, ones' application is not going to be as simply as gas-discharge visualization or so on. I hope in that for your own creativity. I will write here little bit later some information helping to make it right, and I will write some clues to you personally with a hope, that you will succeed practically. Such a success should give a patent and commercial outcome. So I will do it with a hope for your word not to forget me if you will get this success in experiments at your firm. The experiments seem to be not very complicated.
I respect others research and work and can not infringe. If you need small help then I may be willing to do so for your institute for the purpose. Working with neutrons you will need detectors of neutrons along with gamma (protons and gamma). You can try detector like NE213 scintillator or Lithium-7 Fluoride based scintillator or some organic scintillator with lots of Hydrogen in it. You require (n,p) reaction to know the effect of LET. What exactly you are looking at and how will it serve your purpose?
