Previous in Forum: Using Pressure Transmitters as Level Transmitters   Next in Forum: AI Bits and AO Bits
12 Bit AI and 16 Bit AO
09/14/2009 3:57 AM
What is the meaning of BIT in AI & AO?(i.e. 12 BIT AI, 16 BIT AO)
Re: What is the meaning of BIT in AI & AO?
09/14/2009 6:07 AM
It is a resolution.
Pakistan - Member - New Member Engineering Fields - Energy Engineering - New Member
Re: 12 Bit AI and 16 Bit AO
09/15/2009 12:15 AM
the no. of bits used to represent an analog signal defines its resolution. The higher no. of bits used, greater will be the accuracy of the quantized signal to its original value.
India - Member - ADIL MOULA Engineering Fields - Instrumentation Engineering - Adil Moula
09/22/2009 11:21 AM
bit is the binary form where 1 = hi and 0 = lo
This bits are programmed inthe image tables where certain allocation of memory are assigned for AI and AO bits AI and AO module convert analog signal into digital signal which is in form of binary signal and are allocated to the image tables for further processing of the signal this what we see in seimens PLC
hope you get it
Adil
Register to Reply 3 comments
afifahasan (1); Anonymous Poster (1); find2am (1)
