Previous in Forum: Current Transformer Types   Next in Forum: Restaurant Equipment and Fast Food
8 comments
Current Transformers and Bidirectional Sensing
09/14/2009 4:20 AM
Is C.T will sense the current in both direction. As i know the C.T will sense the current in only one direction
Re: C.T will sense
09/14/2009 7:46 AM
Define C.T please. My crystal ball is in the shop being polished.
Good Answers: 103
Re: C.T will sense
09/14/2009 9:03 AM
How the CT (I think you mean current transformer) function ?
Think about it and the answer will be clear.
Ammeter (AC) does it sense current on both direction or one?
If you reverse the polarity of the voltage transformer does it become open circuit/shortcircuit/nonfunctional?
Re: C.T will sense
09/14/2009 11:11 AM
CT can sense it but the direction of current will be change so u have to connect every thing upside down ..
regarding voltage transformer the direction will be reversed ..
correct me if i am wrong
i am learner
Correct me if i am wrong i am learner
Good Answers: 103
Re: C.T will sense
09/14/2009 12:18 PM
The AC current is measured as RMS value, and on that there is no directional sense.
Let us talk in a relativistic approach shold we?
As far as ammeter (or CT) is concerned, it does not know what is phase and what is neutral.
Connect one end to red and call it phase and other to black (and call it neutral) one half of the cycle is + and other is - and it measures the voltage.
Connect otherway round and what happens? still one half is + (corresp to other) and other -
Got the concept?
This does not happen in DC.
In either CT or PT, not the direction the phase angle will be shifted by 1800.
The analogue/digital meters will be still reading the same values as the reverse connected. The problem happens when this signal is used for comparison/processing with some other signal (say Voltage for power) now the shifted phase angle creates problem.
Another problem may happen if the something CT/Meter has graded insulation ie the neutral side has a weaker insulation (the neutral-earth voltage is not expected to go high !) and the other side is connected to ground. But that is possible in even un-reversed connection.
BTW: Am I doing someone's home work?
Good Answers: 244
Re: C.T will sense
09/14/2009 12:20 PM
No doubt the CT will sense with same accuracy but the polarity will change. The change of polarity will affect if the CT burdens (loads) are polarity sensitive such as wattmeter, energy meter, PF meter, reverse power protection relay, directional current relay etc.
- MS
Good Answers: 103
Re: C.T will sense
09/14/2009 1:31 PM
Re: C.T will sense
09/15/2009 2:58 PM
Oh my. I have sensed some unusual sensitivity revealed by a normally very understanding and accommodating gremlin.
I do hope everything is well in your world sb.
CJM
I do not 'know it all', but i will admit that I would like to. CJM
Good Answers: 103
Re: C.T will sense
09/15/2009 10:19 PM
Not sensitive, just getting a bit irritated by the engineers. I am finding too many posts on the foundations of engineering.If people do not understand the basics then how do the will like to work on it?
And not only here, even on work i find quite senior so called engineering graduates with missing foundation.
Just a few days back I had to CONVINCE some whether megger test is destructive or non-destructive. One of the persons (senior) had to be forced to change the machine oil after the sump was flooded and there was some water entry in hydraulic tank of a critical machine. He wanted to use the drain plug and since water is heavier, remove it from there.
Now if one does not understand CBCT or its full form and its circuit, is it expected that we take this forum as one of teaching/ homework solving ? .
This OP's 1981 means he has not passed out from college long back plus he has a bit of working experience too. Should he ask all these questions?
(Solid vs Stranded every one missed the skin - AC/DC). My home telephone is solid, as is the cable connection. Stranded- costlier but necessary. Solid cheap - but ... (mechanical strength can be compensated by putting a steel wire at the core- as we learnt long back in college)
Register to Reply 8 comments
CJMcGill (1); ikhanuk (1); lyn (1); msamad (1); sb (4)
