Previous in Forum: Diesel for Ignition   Next in Forum: Electrical Circuits and Air
14 comments
Field Test to Identify Silicone
09/15/2009 11:35 AM
Hello,
I'm looking for a field test to verify that a sealant is in fact silicone. Is there a "litmus" or similar test that can be easily performed in the field to verify the sealant is Silicone? I am looking at a sealant that looks like Silicone but the supplier swears it is a "Fenzi" (Italian Co.) made Polysulfide. This product has no odor, a slick surface, is black, about a Shore A 40 hardness and the experienced workers here are convinced by it's appearance it is Silicone. I have requested a confirmation form the manufacture who stated verbally it is polysulfide. Conversely is there a field test for polysulfide?
Thanks
Re: Field test to identify silicone.
09/15/2009 4:39 PM
If you have known samples of both materials, you could use the flame/hot knife/sniff test. First test your known materials then compare the odors to the unknowns.
This will give you a guide: IDENTIFICATION OF A POLYMER
Don't inhale too much smoke when performing the test.
Good luck!
09/15/2009 4:57 PM
Thanks - I will give it a try
If you die in the south - going up or down - you have to go through Atlanta - and there will be a layover.
Re: Field Test to Identify Silicone
09/15/2009 9:23 PM
The other thing that comes to mind is a razor blade penetration test.
If you push a single edged razor blade into silicone, it will penetrate the silicone much more readily than the polysulfide.
Use some form of weight and see how much force it takes to penetrate the silicone.
Then go to polysulfide and you should see much less penetration of PS with that weight. Add weight till you get penetration and compare.
These are all very subjective. You could have it analyzed.
Good Answers: 109
09/16/2009 4:57 AM
Burn the stuff to ashes: silicone will give some fine white dust of silica.
Polysulphide will have some smell as sulphur at burning.
Burn with oxidative conditions and only a small sample otherwise toxic.
RHABE
09/16/2009 9:06 AM
Thanks,
this test Worked well - Along with other tests provided by respondants I have determined the sealant I'm working with is Polysulfied.
Great Forum - Very informed and intellegent readers/participants.!!!
09/16/2009 9:17 AM
This is final test and have done to differenciate between silicon and other adhesive when needed.
If it is actual part in field used pin to poke the seal and then known silicon and other and is very subjective but give info one need to go further to confirm or not
Masyood
09/16/2009 2:18 PM
Would a durometer test provide the same information ?
09/16/2009 3:29 PM
Yes
Masyood
09/17/2009 5:19 AM
Firstly, is there a specific reason for needing silicone? If polysulfide works, why not use it? Silicone stands 250ºC continuously Controlled temperature soldering irons are available. Set to 250ºC and keep incontact with the sealant. If it passes it should be OK. Of course Viton will also pass this. However, if a vendor is willing to give you something that costs twice as much as silicone for the price of silicone, that is the vendor's problem.
Bioramani
bioramani
09/17/2009 7:07 AM
Thank you for the information. In my application the issue is
cohesion to another sealant - a butylene. esentialy - The butylene will not adhere to the silicon to the point I could simulate and observe cohesive failure. That is, the two materials will peel apart leaving two slick surfaces.
09/17/2009 7:45 AM
If minimising cohesion to another surface is the issue, can you consider the option of smearing a hiigh viscosity (20000 centipoise) silicone oil between the two contacting surfaces? This is the silicone used for lubricating disposable sterile syringes. Even after five years of being on the shelf the plunger will move effortlessly in operation.
This will free you from selecting an inherently non stick sealant.
bioramani
09/17/2009 11:20 AM
Sorry for the misunderstanding - Actually I'm trying to improve cohesion. That is, the butylenes will not stick well to the silicone base sealant. So - I must not use silicone base adhesive or come up with a way to improve the cohesive bond between silicone and a polymer such as polysulfide. My first problem was determining what I had. Input from other correspondents provided me the information to test for silicone. I had Polysulfide. I have since made several sample coupons of various known sealants for future identification testing's.
In earlier life working for the big companies there was always a lab handy on campus to get your analysis in fast turn around. I miss the big $ environment and the technology but really enjoy the lack of nemesis I have here.
Now that I have found you helpful folks out there I think I will just stay where I'm at. - 3 more years to Retire.....then my time will be working on something between becoming a Rock star and/or a doting grandparent. ?? I'm already a doting grandparent ( which means a major drain on the finances) and have little to no musical talent.
09/17/2009 12:39 PM
Am seventy and have not retired yet. But I am 100% with you about being a doting GP, though the little girl is half a world away in Maryland.
bioramani
09/17/2009 1:42 PM
Good Luck my friend- Go and see her if and when you can.
bioramani (3); lyn (2); Masyood (2); RHABE (1); tom@windoor (6)
