Previous in Forum: Electrolysis of Water   Next in Forum: Heat-Resistant Clear Plastic
9 comments
What's This Product Made Of?
09/15/2009 10:41 PM
Does anyone have any idea what this product is made out of? http://www.fastcap.com/products.aspx?id=4682# http://vimeo.com/2984850
I learn most of everything I know from wiki...
Re: Does anyone have any idea what this product is made out of?
09/15/2009 10:47 PM
Ultra-High Molecular Weight Low Temperature Thermoplastic. Similar to nylon and polypropylene in toughness.
http://shapelock.com/page2.html
09/15/2009 10:50 PM
09/15/2009 10:52 PM
aka "UtilePlast"
http://www.utileplast.com/
(are you getting the picture?)
09/15/2009 10:57 PM
and if you want to get really technical: polycaprolactone (PCL)
http://en.wikipedia.org/wiki/Polycaprolactone
09/15/2009 10:57 PM
If the heating and moulding process is repeatable (in that you can place in boiling water and reshape the material again and again), then some form of thermoplastic polymer.
http://en.wikipedia.org/wiki/Thermoplastic
If the heating and moulding process can only be done once, then some form of thermosetting polymer.
http://en.wikipedia.org/wiki/Thermosetting_plastic
Obviously the material has a low transition temperature but not too low (in that easily obtainable boiling water will cause it to soften but not body heat during use).
09/15/2009 11:33 PM
09/16/2009 1:19 AM
It's slightly rubbery when it hardens though how do you add that property?
Re: What's This Product Made Of?
09/17/2009 8:30 AM
Apparently, it's made out of advertising.
These little sayings down here are irritating. -- Me.
09/17/2009 1:37 PM
its the same stuff that mouthpieces are made out of.
grab a mouthpiece from big5 throw it in boiling water, then into ur mouth and wham bam thank you mam, a mouthpiece that protects you from biting your tounge off and its super comfortable.
Register to Reply 9 comments
anchange (1); Anonymous Poster (4); jack of all trades (1); luvin_the_rings (1); lyn (1); rocketsurgeon (1)
