Previous in Forum: How to Reduce the Manganese in Cast Iron (S.G)?   Next in Forum: Brazing Metals in HVAC and Refrigeration
8 comments
PVC Manufacturing Process
12/22/2006 12:42 AM
hello,
I would like to know about PVC manufacturing process. there are main two process of PVC manufacturing 1) ethenol process 2) calcium carbonate.
I would like to know about complete manufacturing process of PVC by calcium carbonate's roots.
And also if there any manufacturer from china/taiwan/india.
I am waiting for your valuable reply.
thanks.
Re: PVC Manufacturing Process
12/23/2006 2:37 AM
Vinyl Chloride from Ethylene and from ACETYLENE is old hat.
Today Mega-Vinyl is synthesized direct from Ethane(most Natural gases have 1 to 5% ofC2H6)+Chlorine
Search the Net. You will find many more
12/23/2006 6:50 AM
thanks for your reply.
But I would like to make project regarding PVC process by calcium carbonate.
If you have a any details/docuements or web site please reply.
once again thaks,
12/23/2006 7:04 AM
PVC=POLYMERIZED VINYL CHLORIDE
Calcium Carbonate=CaCO3
Vinyl Chloride = CH2--CH2 -Cl(simply)
Not possible any way!
Please get Academic Help
12/23/2006 6:22 PM
Calcium carbide + water forms acetylene.
acetylene + HCL results in vinyl chloride monomer (VCM), a known carcinogen.
Good Answers: 137
01/02/2007 4:34 AM
Reply to #3 and #4
You can make ethyne (formerly called acetylene) hence PVC from CaCO3. I don't all the practical details, but the principle is as follows.
Heat the CaCO3 in a limekiln to produce quicklime. CaCO3 = CaO + CO2 (this has been done for centuries if not millennia)
Mix the quicklime with carbon (powdered coke) and heat strongly. This produces calcium carbide. CaO + 3C = CaC2 + CO.
Add water to the calcium carbide to get ethyne. CaC2 + 2H2O = C2H2 + Ca(OH)2.
Then make VCM (see #4) and polymerise it (sounds easy!)
Once you get going, you only need (again in principle) a small input of CaCO3 for make-up, as the CaO can be recovered by heating the Ca(OH)2, and recycled.The only net inputs on the carbide part are carbon and water.
01/02/2007 12:20 PM
Poly Vinyl Chloride=PVC
Where/how will the Chlorine come in/from?
Re: PVC Manufacturing Process from carbide
02/07/2007 1:08 AM
hi, i m mayur patil from kota, rajasthan
i m working as a assitant engineer in shriram fertilisers and chemicals limited, we are manufacturing pvc resin from calcium carbide root so if u need more data log on to www.dscl.com this is our companys website. see u again
my mail is mayurchem13584@yahoo.co.in
10/16/2009 3:37 AM
i need process flow diagram for pvc manufacturing process from vinyle chloride monomer
Register to Reply 8 comments
Anonymous Poster (3); Codemaster (1); Manish Ramavat (1); MUKULMAHANT (3)
