Previous in Forum: Extending the Life of a Wastewater Pump Impeller   Next in Forum: Boiler Tube Welding Repairs
Heat Exchanger Outlet Pressure
09/16/2009 2:21 PM
HI
i have a heat exchanger but the outlet pressure more than inlet by 1kg/cm2????????
Re: heat exchanger
09/16/2009 3:12 PM
can't be, is your gauge branch off the stream, or is the stream in direct line of the gauge?
Good Answers: 137
Re: heat exchanger
09/17/2009 4:09 AM
Only way it could be is if he's referring to different circuits. The outlet pressure on the cold side could be higher than inlet pressure on hot side, or vice versa.
Cheers.........Codey
Re: heat exchanger
09/17/2009 11:10 AM
Then we're all guessing.
Re: heat exchanger
09/16/2009 3:13 PM
It could be the outlet diameter is smaller than the inlet, might want to check that.
Charlie don't surf.
Re: heat exchanger
09/16/2009 3:14 PM
that would only increase velocity.
Good Answers: 58
Re: Heat Exchanger Outlet Pressure
09/16/2009 8:17 PM
What I like to do in such cases is have one gauge hooked up to both locations. A double inlet single outlet valve will remove any questions about gauge accuracy. It makes a simple hookup, and both readings are taken at the same spot.
mike k
Register to Reply 6 comments
Codemaster (1); mike k (1); phoenix911 (3); stevem (1)
