Previous in Forum: Why Would You Want an Electrical Isolated Ground?   Next in Forum: Leakage Currents
MEMS
09/16/2009 9:42 PM
Hi All
can anybody help mein resolving this ques:
A (100) silicon wafer is subjected to two oxidation steps. In the first step the wafer is placed
in a furnace for dry oxidation at a temperature of 1000°C for 1 hour and 40 minutes. a) Find
the thickness of the oxide layer grown on the silicon wafer? Now the same wafer is oxidized
again, but this time in a wet ambient at a temperature of 900°C for 1 hour and 20 minutes.
B) Find the thickness of the new oxide layer grown on the wafer? C) What is the total
thickness of the oxide on this wafer? D) How much silicon is consumed to make the thermal
oxide layer during the oxidation cycles?
Re: MEMS
09/16/2009 9:48 PM
Homework?????? Certainly sounds like homework!
Re: MEMS
09/16/2009 10:18 PM
:-(...any help???
Re: MEMS
09/16/2009 10:51 PM
This really does look like a homework question you know.
http://cr4.globalspec.com/faq
Have you tried looking in your (or a) text book for the formulas applicable to silicon oxide formation using the variables of temperature, humidity, time (and possibly pressure)? There will be one (or more which govern oxide formation), no I don't know what they are sorry but these links may send you in the right direction.
http://en.wikipedia.org/wiki/Silicon
http://en.wikipedia.org/wiki/Silicon_dioxide
Re: MEMS
09/17/2009 5:07 AM
Here are some outline notes of a lecture about it. There are also some references to textbooks. You may need a trip to the library!
Good Answers: 59
Re: MEMS
09/18/2009 10:46 AM
You really should have taken notes during lectures.
Notes: Assuming that this is a coursework question, you should be expected to show how you calculated this based on whichever of surface reaction rate, solubility, and diffusion rate are dominant. You also need to make some assumptions (partial pressure of O2 and steam for each case - this is usually taken as atmospheric for student questions, but is often very different in a practical fab). I expect that you were given the figures you need, but if not you can easily find them in Sze's "Physics of semiconductor devices" or even on the web.
jack of all trades (1); JohnDG (1); lyn (1); Physicist? (1); soniaj (1)
