Previous in Forum: Tan Delta Test of Transformer Oil   Next in Forum: Power Stabilizers
Switchgear and Fuses
09/18/2009 12:24 PM
Can any one please tell me, How do we get, making and breaking capacities of Switchgear and Fuses???
And also what is Relay range of Circuit breakers???
Please guide me
Location: N.E. Alberta 55.6329 N Lat. 111.0729 W Long. Canada
Re: Switchgear and Fuses
09/18/2009 4:54 PM
You look it up on the sheet provided by the supplier for your switch gear. You wouldn't buy a car without looking at the specs. ALL solid blade and fuses are NON load break, unless they have a add-on. Use a breaker or OCR to do the dirty work.
Part two, of your question!! What are you on about?????
Relay range should be mated to your CB?????
Part three: I should guide you to a tech. school, a university or a good library. They still have libraries don't they?
Could be worse, it could be me. :)
09/19/2009 7:43 AM
1-read manufacturers datasheet.2-but about fuese it needs an experimental work.
warning: "this experiment should only be done by an expert person mentioning all conditions".
you need an adjustable current power supply ,an ampere meter and the fuse in a circuit ,by increasing current from 0 the fuse wire takes hot goes red and finally burns out ,if burning time equals to 5 second for fast or 20 seconds for slow type fuses we can roughly say :fuse rating then is about .4 times the mentioned current.
warning: "this experiment should only be done by an expert peson mentioning all conditions."
You might be interested in: Fuses, Panelboards and Switchgear
