Previous in Forum: VFD / Eddy Current Drive and Automatic Power Factor Correction Relay   Next in Forum: Drive Module for AC Servo Motor
Which Pump is More Efficient?
09/21/2009 11:26 AM
Sir:
May I know which Pump out of the following three is the most efficient for Negitive Suction Application for water supply application from a well ? ( suction lift 3.5 mt to 4.5 mt ).
We may consider Three Phase 415V , 50 HZ , 15HP Pump for 10 Years LCC having 16 hours working ( daily ).
1) Centrifugal Monoblock Pump
2) Submerged Centrifugal Pump
3) Centrifugal Monoset Pump
Which are the key governing factors to be considered while purchasing the most efficient pump for the abovementioned application?
Pl guide.
Tushar Shah
Good Answers: 101
Re: Which Pump is more efficient ?
09/21/2009 11:55 AM
Each pump will have an efficiency rating from the manufacturer...
09/21/2009 12:43 PM
A submerged pump would, by definition, have a flooded inlet and NPSH equal to the level of the water above the inlet.
So, #2.
09/21/2009 11:38 PM
Plus about 10 m.
Good Answers: 18
09/22/2009 10:45 AM
I agree. All else being equal, I would opt for the submerged pump.
Re: Which Pump is More Efficient?
09/24/2009 9:54 AM
You have to study the pump characteristic curves and select a pump with maximum effiecy at duty point that is at given headand flow.Such casulal answers cannot be taken
agua_doc (1); Anonymous Poster (1); lyn (1); nesubra (1); RVZ717 (1)
