Previous in Forum: Small Water Turbines   Next in Forum: Planetary Rolling Die
Motor Heat Generation Calculation
09/21/2009 12:14 PM
Can anyone tell me EITHER how to calculate, OR how much heat is generated from a
440 hp motor??
Thanks
harpee
United States - Member - Engineering Fields - Mechanical Engineering - Hobbies - Fishing - Hobbies - Musician -
Good Answers: 19
Re: Motor Heat Generation Calculation
09/21/2009 5:01 PM
You need to know the motor efficiency (η). Heat rejected from the motor will be (1 - η) * 440 hp * (746 W/hp) * (3.413 BTU/W) - however, this does not include any heat rejected during work done by the driven equipment within the space. For such a large heat load, the motor most likely utilizes a cooling water source.
09/22/2009 12:26 AM
It is simple. The entire inductive reactance power will be converted to heat.
The I^2r loss heat to be added.
thanks,
dhayanandhan.s,
india
09/22/2009 7:42 AM
A good place to start is the nameplate on the motor, it should list the efficiency.
09/24/2009 5:47 AM
Perhaps the below standard could help you, I usually do the calculations for the ventilation of engin rooms with this ISO
ISO 8861 Standard
Shipbuilding – Engine-room ventilation in diesel-engined ships – Design requirements and basis of calculations
Register to Reply 4 comments
Anonymous Poster (2); cuco48 (1); dac1267 (1)
