Previous in Forum: Small Transformers   Next in Forum: Current on Transformer Primary Side
Two-Pole Induction Motor: Effect of Frequency and Voltage
09/21/2009 3:15 PM
I have a 2 pole induction motor used for pumping fluid around a system.It is 3 ph and rated at 440v 60 hz it draws 4.2A at full load curent.The motor is wired in star configuration.
If i run the motor at 480v at 50hz what would happen to the current ? Increase or decrease and why ?
Labtech5555 Location :UK
Good Answers: 244
Re: Two-Pole Induction Motor: Effect of Frequency and Voltage
09/21/2009 7:17 PM
See the previous thread. http://cr4.globalspec.com/thread/33399
It has a very good information with an initiative of guru 'SB'.
- MS
Good Answers: 50
09/22/2009 3:32 PM
You can see from the other linked information that the current rises significantly and you will likely see the motor fail if you apply 480V 50Hz. The losses increase in the motor alot so I guess this is a high risk strategy.
In any event, you will only be pumping at 5/6 speed so your system will be starved of flow / pressure, so why do this?
The easy answer at low cost (for 3HP application?) is to use a VFD, which you set for a 440V 60Hz wound motor. Normally, you would connect this via your normal supply, which is 400 / 415V in UK. if you have 480V, this is also OK, just remember to set the output as 440V / 60Hz. The 10% drop in voltage at full speed if you only have 400V is unlikely to have any detrimental effect.
If your supply can also be 230V-240V, you can also use a single phase input VFD and connect the motor in Delta if this is preferred, motor rated current would be √3 x your Star rated Current on the nameplate.
Something new every day!
Register to Reply 2 comments
