Hi,
I have selected a Axial flow fan with 6000 cmh @ 75 Pa & 1350 RPM for evaporator coil.
Now, pressure of evaporator coil is changed from 75 Pa to 90 Pa with same flow. Now, my motor has maximum 1350 RPM. Now, is it possible that this fan will run in stall area and will make more noise?
Also, I wanted to know how fan can go in stall area if speed of motor is restricted and manufacturer give curves for 0 to max speed.
Regards,
Keyur
