Previous in Forum: Gas Engine Ventilation Calculation   Next in Forum: Axial Flow Fans
Gas Consumption per Kilowatt
09/22/2009 4:12 AM
Can Someone tell me Approx Gas Consumption/hr if of a Genset of deutz . The Genset Rating is 3876 kw
Hobbies - Hunting - Deer and Birds Hobbies - HAM Radio - Achieved Ham Radio license in 2008 Hobbies - Fishing - Fisherman United States - US - Statue of Liberty - Know freedom, no tyranny.  Know tyranny, no freedom. Hobbies - DIY Welding - Beginner
Good Answers: 19
Re: Gas consumption per killowatt
09/22/2009 9:41 AM
I use solar panels, battery bank and invertor for my home in NW Washington. About once every year or two I have to fire up my Genset to bring batteries up if it has snowed for weeks and weeks and the clouds have been too thick. My 10 kW Genset uses 2 gallons (US) per 8 hours of run time. However, the load on the Genset is relatively constant and is at 1/2 kW power applied to re-charge system. You would need to calculate the load required, as the load will provide force against the engine which will affect gal/hr. You could also run a few trials and log the consumption. This isn't answering your question directly, but hopefully provides some things to look into that will help you get there.
Go green, use a solar powered light saber...
09/22/2009 10:11 AM
thanks.but i m looking for something like disel consumption for load.because our genste fluid is natural gas.so i need gas consumption for load.
09/23/2009 1:21 AM
If you are using Natural gas with NCV of 9000 Kcal/Nm3, then as per Deutz gas engine, the gas consumption shall be about 0.258 Nm3 per kwh. Hope this helps you. Regards, Ram
09/23/2009 3:26 AM
is there any graph for this or data sheet.
Engineering Fields - Mechanical Engineering - New Member Popular Science - Weaponology - New Member Turkey - Member - New Member
09/25/2009 8:12 PM
Hi (calorafic value) FOR NG 34.02 Mj/m3 then,
Q=Hi x V x 0.278
Q = Heat input kW
V = Gas consumption m3/hr (For your question V = 409.83 m3/hr (0.106 m3/kWh)
Anonymous Poster (1); chowdhuryakik (2); GWHITE (1); Matt Skywalker (1)
