Previous in Forum: Electrical Cable Sizes   Next in Forum: Contactors
9 comments
APIX Pilot Plant Design Project - Member - New Member Engineering Fields - Chemical Engineering - Member Engineering Fields - Environmental Engineering - New Member
DC Connectors in Adapters
09/22/2009 4:16 AM
"Cigarette" and "Air" type of DC connectors in adapters. My laptop has the DC output connection that looks like a hollow pipe with a pin jutting out from the centre. What is this connector called?
Shalom
Pathfinder Tags: DC adapter
Re: "Cigarette" and "Air" type of DC connectors in adapters
09/22/2009 4:58 AM
No special name, AFAIK. It's just a miniature DC power connector. I believe Dell use one with a plug OD = 5.5mm & pin diameter 2.5mm, like this.
09/22/2009 10:48 AM
I've heard 'em called 'Roker' plugs, but that was long long ago, far far away.
No, not in a distant Galaxy.
09/22/2009 11:11 AM
A google search for "roker plug" got 9 hits - 4 of which referred to the connectors in question. Del gets a GA (for having a memory that works).
09/23/2009 12:57 AM
Interesting... I've never heard the term "roker plug". A Google search for "roker plug" from here in the USA produced only one hit referring to those plugs - a JG something company.
Most of the rest were 'plugs' of/for TV personality Al Roker.
To the Original Poster: Before the advent of the wonderful MagSafe™ power connector, most Mac laptops had a power connector that fit your description, but a closer examination would show that the center 'pin' is actually three concentric connectors. This is also called a coaxial power connector, as mentioned by a previous post.
Safety - Hazmat - Environmental, Safety & Health Manager Hobbies - Musician - Theremin (That about says it all...)
Good Answers: 19
09/22/2009 11:21 AM
zasmine,
(I am presuming that you are referring to your laptop having a DC input, as opposed to output)
The connector in question is referred to as a "coaxial DC power jack", and the mate is the "coaxial DC power plug".
The different size plugs and mating jacks are referred to using letter designations: For specifics, check with either Mouser or Newark electronics....
Just my $0.02...
09/22/2009 11:44 PM
Regards
I agree to your reply.
It is as in the link of RS products' catalogue in of post #1 :
It is Mini DC Power Plug
Mini DC Power Plugs & Sockets
Re: DC Connectors in Adapters
09/22/2009 11:01 PM
Thank You fellows
Shalom
09/24/2009 5:52 AM
that is a DC mel cinnector or socet.
Qualitative Cigarettes Online
12/15/2010 5:42 AM
thank you for the posting. I would like to suggest you http://www.cigarettes-shop.net/.
100 % service guarantee.
Register to Reply 9 comments
Anonymous Poster (1); dkwarner (1); Haajee (1); JohnDG (2); subhajit (1); The JMAN (1); user-deleted-1105 (1); zasmine (1)
