Hi all iwould like to rotate my wind power generator with electric motor.i would like to know that wind power out put is to go in put of that motor which is rotate this wind generator.
Is this to simulate the wind for a test (and test the wind power generator)? If so it is largely dependent on your blade size and design, gearing, electrical load on the wind power generator output, height of the turbine, wind direction, etc, etc. There is too little information and too many variables to be able to answer this question.
Please explain the application and size of the wind turbine in more detail and as clearly as possible.
hi thankyou for your kind interest,you ask me brief my question.actually i want use only wind generator with out blade,tower same like fan with out blade.i think if my wind rotor 5kva ,is it possaible electrical ac/dc motor capacity like 2 ,3 hp rotate my wind turbine bcz wind turbine need very low rpm produce electricity.
