Previous in Forum: GD2   Next in Forum: CT Dimensioning K Factor
Current and voltage in resistor?
09/23/2009 6:50 AM
i want to know one nonpractical problem's solution. if we connect three 20V ideal DC voltage source and one 20ohm resistance in prallel to these votage sources then what will be the current and voltage in resistor? all four elements are in parallel
Re: pradeep from Lucknow
09/23/2009 7:03 AM
hai friends
as ur question u find 20v voltage & 1A current in curcuit.
09/23/2009 7:29 AM
You don't say how the voltage sources are connected...
1 ideal 20v voltage source is exactly the same as 3 ideal 20v voltage sources connected in parallel (or any other number).
3 ideal 20v sources in series is the same as one ideal 60v source.
Good Answers: 53
09/23/2009 7:40 AM
3 Ideal sources in parallel are as good as one ideal source, Its like adding infinity 3 times.
Good Answers: 143
Re: Current and voltage in resistor?
09/23/2009 8:07 AM
Grasshopper, first you must sit in lotus position. Then repeat mantra, "Ohm, Ohm, Ohm". When you have emptied your mind of everything else, then you will see that ideal Voltages sources in parallel only provide longer operating time. 1 A, -20 V.
Good Answers: 88
09/23/2009 10:57 AM
Heard NASA is hiring. Why not give it a try?
09/23/2009 11:44 AM
<SPLARF>
How do I get this tea off my screen?
09/23/2009 4:06 PM
A question for grade 8 or 9 student.
Anonymous Poster (1); nkverma125 (1); rakesh_semwal (1); SimpleMind (1); TVP45 (1); user-deleted-1105 (2)
