Previous in Forum: Starters for HT Motors ( 1.1 KV,800KW)   Next in Forum: Wind Power
Capacitor Bank Panel
09/24/2009 2:14 AM
sir,
with reference to title i would like to know how i connect the capacitor panel having total connected load of 10.5 MVA with five distribution transformers.
Re: capacitor bank panel
09/24/2009 3:30 PM
I am assuming you want to connect power factor capacitors to distribution transformers but don't know where to start (not that you have a power factor correction panel already designed and supplied and you don't know how to wire it up).
For a specialised distribution application like this you are much better off getting a solution designed and supplied by a power factor capacitor panel supplier.
Do you know how many KVAr of corrective capacitance you need?
Do you know what your load power factors are (including the variation size and rate of change profiles)?
Do you need fast small corrective action, slow large corrective action or somewhere in between?
What's the voltage? etc.
If you don't have answers to all the above questions then you also need to have a proper power factor assessment and design done (randomly putting a bunch of capacitors in is a recipe for disaster).
Also see previous threads on CR4 for more information on the subject.
Re: Capacitor Bank Panel
09/28/2009 12:18 PM
Consult a specialised installation supplier.
Register to Reply 2 comments
