Previous in Forum: Evaporator Design   Next in Forum: Refrigerant Compressor Capacity
India - Member - New Member Germany - Member - New Member France - Member - New Member Engineering Fields - Mechanical Engineering - New Member Popular Science - Weaponology - New Member Engineering Fields - Energy Engineering - New Member Hobbies - RC Aircraft - New Member
Slider Bearing
09/25/2009 8:12 AM
Can anybuddy tell me about slider bearing/joint bet piston rod & connecting rod of small steam engine.
Be an engineer not a degree holder!
Good Answers: 143
Re: Slider Bearing
09/25/2009 8:19 AM
I'd use either one of the bearing bronzes or a plastic.
Re: Slider Bearing
09/26/2009 1:47 AM
Crank rotates and Connecting rod's big end is linked with crank pin. Small end of connecting rod is connected with piston rod. Cross-head is the special element used for this connection. It is special incense, it has to accommodate the linear movement of piston rod, accommodate the arc-wise movement of connecting rod small end joint with this cross-head and accommodate the linear sliding movement of the this entire assembly.
This assembly is typical for steam engines, IC engines and compressors as well. Have closer look at my 'avatar' which might explain this assembly in motion.
This is a very general description of this cross-head assembly. What else in specific you would like to discuss in detail?
Re: Slider Bearing
09/26/2009 4:20 PM
If I was building this myself, I would look into the linear ball bearings, as used on punch presses.
Re: Slider Bearing
09/28/2009 12:43 PM
The crosshead slides on the slide bar(s).
The piston rod and the connecting rod are connected with a pivoting bearing.
The lubrication arrangements will differ.
How about a chat with the Honorary Locomotive Superintendent at the local heritage steam railway?
Register to Reply 4 comments
CFECO (1); PWSlack (1); TVP45 (1); yesyen (1)
