Previous in Forum: Odd Order Harmonics   Next in Forum: Over All Screen and Individual Shield termination in Marshalling
Negative Pressure in Kiln / Afterburner?
09/25/2009 1:05 PM
Hi
I'm new to the instrumentation game, and I have to monitor the negative gauge pressure in a rotary kiln and afterburner, with temperatures at 1100 Celsius and 1700 Celsius, respectively. Any ideas about the type of sensors and accessory equipment best suited for the job. Readings will need to be looped to a plc.
Thanks
Re: Negative Pressure in Kiln / Afterburner?
09/26/2009 12:40 AM
Use tubing to carry the pressure out to to a friendlier location. At 1700°C, you might have to use ceramic tubing.
09/26/2009 3:21 PM
Since you are measuring vacuum if all goes right the heated gas does not get to the gage. Like dkwarner said connect it with a length of tubing. I have several vacuum sensors in a similar application that work fine. The tubing should be long enough or of a material so as to not conduct the heat to the gage. With a length of small tubing and no leaks at the gage this could maybe even tolerate short times at a positive pressure.
Everything I know about opera I learned from Bugs Bunny
Good Answers: 183
09/28/2009 3:31 AM
Attention: Ceramics have in general a high thermal conductivity so that the length has to be quite big till you reach an acceptable temperature.
The best solution could be a double tube with an air cooling flow between the two components and at the end a tube of SS which has a lower thermal conductivity and could be shorter. To make it shorter you could use fins when the tube is outside of the hot chamber.
Register to Reply 3 comments
DaveB (1); dkwarner (1); nick name (1)
