Previous in Forum: Volume Flow Rate Measurement   Next in Forum: Standardization of HCl solution
17 comments
Unit of Measure for Volume Flow Rate of Gas
09/25/2009 1:50 PM
In the volume flow rate measurements which type of unit must be used: either "ml/min" and "cc/min" or there are some differences ?
Pathfinder Tags: flow flow rate unit of measure
Good Answers: 143
Re: Unit of measure for volume flow rate of gas
09/25/2009 2:04 PM
Please say something about what is flowing. Read your previous post.
Good Answers: 101
09/25/2009 2:09 PM
Yes... Please clarify. Depends on how you intend to use the numbers, and how many unit conversion you wish to do.
09/25/2009 2:10 PM
SI units
09/25/2009 2:29 PM
Isn't a cc and a milliliter the same thing?
09/25/2009 3:22 PM
Yes
09/25/2009 3:49 PM
I don't want to split hairs, but a cc of water only exactly equals a ml at 4 degrees C.
I know we're talking about gas here, but............................
Good Answers: 101
09/25/2009 4:04 PM
Man... now i'm going to need these split ends trimmed off.
09/25/2009 5:12 PM
I must disagree. mL and cc (cubic centimeter) are BOTH units of volume. I would agree that 1 mL/cc of water weighs 1 gram at 4ºC.
09/25/2009 6:08 PM
I stand corrected. You are right!
My humble apologies for misspeaking. A little knowledge is a dangerous thing.
09/25/2009 6:27 PM
I think we've all done it - I know I have!
Cheers
Mike
Re: Unit of Measure for Volume Flow Rate of Gas
09/25/2009 5:10 PM
Whoops, I'm talking about liquids here...
It all really depends on what is accepted by the relevant industry.
I customary use mls/min, L/h is commonly used for the same size of pump.
Just chill and go with the flow, it's not much effort to convert....
09/25/2009 5:14 PM
bad pun - bad kitty!
09/25/2009 8:30 PM
Hmm when I measure gas flow it is not ml/min, it is million standard cubic feet per day, and it is ususally many millions.... the other option is standard cubic meters per hour, and ususally lots of them too...
09/28/2009 4:35 PM
In the gas leakage testing of valve seats, the Sml/min and Scc/min are usually used; some flowmeter use Sml/min other flowmeter have Scc/min.
Referring to the SI (International System Unit) how is it correct to measure the gas flow rate? Sml/min or Scc/min ?
09/25/2009 10:58 PM
Are you talking about only cc and ml (one and the same) or you are talking up on in general about selection of units?
If you want to measure the volume of some small quantity cc is OK, you should not use m^3. But if you want to measure volume of water in some dam.. totally different units will be needed, Using cc as measure is not non scientific, but certainly absurd.
09/25/2009 11:12 PM
I would like to say that ml/min = cc/min = 10-6 m3/min = 10-3 l/min
Good Answers: 103
09/26/2009 1:08 AM
Don't you use NM3/min, SM3/Hr or similar for gas flow rates?
or in your case may be Nmm3/min or Smm3/min ?
Register to Reply 17 comments
Anonymous Poster (1); bill1 (2); gsuhas (1); lyn (2); Mikerho (4); Osayed (1); RVZ717 (2); sb (1); Steve S. (1); TVP45 (1); user-deleted-1105 (1)
You might be interested in: Gas Flow Meters, Flow Meters, Air Velocity Flow Sensors
