Previous in Forum: Converters and Inverters   Next in Forum: Induction Motor Question
9 comments
How to make "input 5-10V output 4-20mA circuit"
12/26/2006 2:42 AM
I have a circuit and i want to add 4-20mA output circuit. ıt must be simple circuit. Do you have an idea?
Pathfinder Tags: 4-20mA circuit design
Re: How to make "input 5-10V output 4-20mA circuit"
12/26/2006 2:23 PM
Yes! easy a simple op-amp and a transistor.... a few resistors as well...
John.
12/27/2006 3:51 AM
good morning first of all.
well, to make this kind of circuit, u just have to adjust the resistors as well as the current flow in the circuit to produce the require current..
it's easy..
09/30/2009 5:51 AM
12/27/2006 1:55 PM
I assume that you are using a single supply and came up with a short article that has a nice description and a simple design: "Voltage-To-Current Converter Works From A Single-Supply Rail" at: http://www.elecdesign.com/Articles/ArticleID/2985/2985.html
Hope it helps.
12/27/2006 4:40 PM
The url is incorrect. The correct url is: http://www.elecdesign.com/Articles/ArticleID/2985/
12/27/2006 4:42 PM
Thank you for your help...!
12/27/2006 5:02 PM
i had found it.i wrote the "enter drill deeper id" edit box article number in the web page.
thanks again
12/28/2006 1:04 PM
try looking at kele, they have this type of supplys,, i have had to convert the same deal for inputs/outputs on a controler,, i think the web site is kele.com and the price's are very reasonable,, (for that type of stuff), its been a bit since i installed it,, but i think it was a transducer,, if cant find,, and in the us,, the ph # is 888-397-5353,, and they have good tech assistance,, and will sell to the common persons,, good luck,,,
have a great day, and make it fun
10/15/2008 12:05 AM
the upper URL is deleted or wrong. please send me again.
Register to Reply 9 comments
Anonymous Poster (5); Electroman (1); spenc (2); whats news (1)
