Previous in Forum: Solar Powered Light (LED) with Charge Capability   Next in Forum: Bathroom Wiring: 12 AWG vs. 14 AWG
Two Sources of Power Feeding Case Breakers
09/28/2009 4:51 AM
what happen if i have 2 sources of power 400v ( from two generators each 1500kva) feeding two molded case breakers each 3200A and each breaker feeding its loads and there is a buscoupler 3200A between them and of corse every breaker has its own neutral from its generator, my question what happen if i made the neutral be unity for all distribution board? an earth leakage current flows in neutral or what?
Re: Two Sources of Power Feeding Case Breakers
09/28/2009 12:00 PM
An earth leakage current indicates a fault.
Check local electrical regulations about what is and what is not permissible.
09/28/2009 1:14 PM
I may be misunderstanding yo but in no case would you want to separate the neutrals. With 2 seperately derived sources each neutral will carry any unbalanced load from it's source.
Tell 'em what they need to hear; not what they want to hear!
You might be interested in: Circuit Breakers, Neutral Density Filters, Load Centers
