Previous in Forum: High volt kit   Next in Forum: DC Motor Replacement
Need Help for Torque Motor
12/26/2006 10:44 PM
I need some tork motor having speed up to 4500 rpm and having torque about 150 gm + and operating voltage 0 to 12 vdc
Good Answers: 75
Re: Need Help for Torque Motor
12/28/2006 4:47 AM
Torque is measured in newton metres, if you gm means gram metres then the torque you are looking for is about 1.47 Nm. It is important to use the correct units, not to do so leads to mistakes.
12/28/2006 5:46 AM
http://dc-motors.globalspec.com/SpecSearch/Suppliers?QID=8449310&Comp=17
This is the globalspec search for 12V DC, 4500 rpm, and, 1.5 Nm
You can easily change the requirements in the ADVANCED search option.
Your cheapest solution for one off may be a good "drill driver": though you won't get 4500 rpm and 1.5 Nm at the same time.
Technical Fields - Education - New Member Technical Fields - Technical Writing - New Member
12/28/2006 8:37 AM
This is the best answer / selection I have seen for the last year!
You deserve some trophy / medal / recognition certificate ....
01/02/2007 4:30 AM
Looks like a small battery-electric drill. Bosch? JCB? Makita? Try the Screwfix catalogue on the 'net and order one over the phone with a credit card.
Register to Reply 4 comments
Anonymous Poster (1); masu (1); Randall (1); southern123 (1)
