Previous in Forum: Induction Motor Question   Next in Forum: Need Help for Torque Motor
High volt kit
12/26/2006 8:47 AM
Hai every body,
In a high voltage test kit ,i have to prove my kit delivering high volt output apart from voltmeter reading , any way is there pls help me.
Re: High volt kit
12/26/2006 2:24 PM
A big enough spark??
United States - Member - Engineering Consultant Popular Science - Evolution - Understanding
Re: High volt kit
12/26/2006 11:42 PM
You don't say how high of a voltage or what amperage capability(why am I not surprised), but there are many ways to demonstrate it. Electroman mentioned a good one: jump a spark if the voltage is high enough. Depending on the voltage you could create a simple circuit with some resistors and a neon bulb and have it light BUT you don't say what voltage.
But it sounds like your teacher won't accept a voltmeter reading (even if you put the appropriate load on your output?). At that point, I would suggest (as a joke) that you have the teacher hold the output leads ... but its just possible someone here would do that with a dangerous voltage so DO NOT!
