Previous in Forum: Neutral Wire Missing   Next in Forum: Calculating Discharge Resistor for High Voltage Capacitors
Dry-Type Transformers
09/30/2009 12:31 PM
I have a 3000kva dry type transformer with the primary voltage of 12470 and the secondary voltage of 720. I am currently running an induction heating system that is a 1000kw system. I have a 2600kw induction heating system that i would like to feed off of the same transformer. the new system is a 550volt set up so I have a 720 to 550 step down transformer rated at 1700kva that i will place in front of a 600volt switch. DO I HAVE ANY PROBLEMS???
Re: electrical ??
09/30/2009 2:30 PM
In this application, probably. You have a 3000kVA transformer powering a 1700kVA step down transformer and a 1000kW induction heater, with the 1700kVA step down transformer powering a 2600kW induction heater.
What power factor is the 1000kW and the 2600kW induction heating systems running at (both loaded and unloaded as this effects power factor)? As a rough guide, if the 2600kW induction heater is running at a power factor of more than 0.65 your step-down transformer is overloaded (0.83 for the 1000kW induction heater).
What is the application (metal smelting perhaps)?
Re: electrical ??
09/30/2009 4:11 PM
there is a problem due to the active power need 2600KW only &the transformer which before the load is 1700KVA , the transformer doesn't sufficient to the load , although the load is unity power factor .
S (appearent power)=P (Active power)/ Power factor
note : S in VA & P in Watt.
Re: Dry-Type Transformers
10/02/2009 4:31 AM
It is not possible unless you want to send some smoke signal to your boss, asking for a salary raised.
Basic calculation indicated that, your additional of 2600KW heaters, will be over loading your 1700KVA transformer by 60%. This means that, your 1700KVA transformer will go up in smoke first.
For example, if you don't use it at 100%, let say at 50%, the total loading will be at 1,487 amp or at 83.4%. and the total loading to your main transformer of 3000KVA is 2,816 amp. That means, that you still overloading your main transformer at 2,816 amp or 14.5% over the rated capacity.
So the answer still NO and YES you do have PROBLEMS.
Good Answers: 88
10/04/2009 8:10 PM
Yes unless you ensure by design that both loads do not engage at the same time. Not enough thermal impedance on a dry transformer, Also pf control recommended
Ahmed Mansour (1); jack of all trades (1); Simon Wan (1); SimpleMind (1)
