Previous in Forum: VDA ISO 16949_ plastic requirement / check list   Next in Forum: Orbital Welding.
Creepage
10/01/2009 3:07 AM
How much minimum creepage require the 12Kv Epoxy Insulation and how the creepage measure.
If, i know the creepage distance on insulator (ex:200mm). How much dry power frequency voltage withstand in the insulator.
Please give abrief note.
Regards,
Koduri
Re: Creepage
10/01/2009 10:33 PM
It depends on the application, the pollution level and any other additional safety margins or standard-specific requirements specific to the construction of the insulator and application.
For example outdoor overhead insulators have a specific creepage length of 16mm/kV for low pollution environments right down to >31mm/kV for very high pollution environments (as per IEC 815).
Specific values can be found in the standard applicable to your specific insulator and application.
What's the application?
Re: Creepage
10/02/2009 3:28 AM
Indoor Application
Re: Creepage
10/05/2009 2:53 PM
The following is a good link. also try a google search of "creepage distance measurement" or similar
http://www.harkis.harting.com/WebHelp/EGds/WebHelp/GBgdsCreepage_and_clearance_distances.htm
http://www.cadfamily.com/Download.asp?ID=290466
It depends on the type of insulator, its construction and if the voltage is continuous or a short pulse. Exactly what type of insulator or product are you using? Have you looked at the insulator datasheet or on the supplier website as there should be a maximum ac voltage rating listed.
Also see previous threads on CR4 on the subject. Here is just one example thread.
http://cr4.globalspec.com/thread/27362/What-is-Creepage-Distance
