Previous in Forum: Cables   Next in Forum: Virtual Image
hallo
10/01/2009 3:46 AM
I m Eng waleed Alzoud and i redye to help any one
Good Answers: 137
Re: hallo
10/01/2009 4:03 AM
Glad to hear it! I hope you won't be helping them with their English
Re: hallo
10/01/2009 4:17 AM
I've got an off-white frock that would much better in red.
Re: hallo
10/01/2009 5:01 AM
how to brake up caste irn bath tub for remove frum tite room
Good Answers: 101
Re: hallo
10/01/2009 5:26 AM
To do what? Understand the meaning of life?
Re: hallo
10/01/2009 10:53 AM
Hmmmm sounds almost as good as my Russian!!!
Hobbies - Hunting - Deer and Birds Hobbies - HAM Radio - Achieved Ham Radio license in 2008 Hobbies - Fishing - Fisherman United States - US - Statue of Liberty - Know freedom, no tyranny.  Know tyranny, no freedom. Hobbies - DIY Welding - Beginner
Good Answers: 19
Re: hallo
10/01/2009 6:02 PM
"how to brake up caste irn bath tub for remove frum tite room?"
cast in bath tub - or cast iron bath tub?
If your cast is on your leg, lay in the bath tub and grab a sledge hammer with both hands and whack away. But once the cast is broken, you can remove the pieces from very small rooms, but you would need to get out of the bath tub first.
If you meant cast iron bath tub...you will need to either cut it with a metal cutting torch, or break down some walls or widen the doorway.
Go green, use a solar powered light saber...
Re: hallo
10/01/2009 6:13 PM
tank you deer Sir - it is custe irn
wat Numbet of hamer kgs
Anonymous Poster (3); Codemaster (1); DVader1000 (1); Electroman (1); Matt Skywalker (1)
