Previous in Forum: LITE DONGLE   Next in Forum: Rectification for Wrong Tapping Point for Liquid Service D/P Flow Transmitter
10 comments
Thermocouple Life Span
10/01/2009 12:57 PM
I need to know the life span of a thermocouple. The reason I am asking this is I am changing thermocouples after about three months. They break or just don't read properly. I am measuring glass at around 1300 deg. C using type B
LUCK: A prepared man meets opportunity
United States - Member - Charter Member Engineering Fields - Instrumentation Engineering - Charter Member
Good Answers: 73
Re: Thermocouple life span
10/01/2009 1:07 PM
You can go up to about 1800 C with a type B. Are you using a thermowell? You should be.
I go into every human encounter expecting to be framed for a crime I didn't commit. Dilbert, 2013
10/01/2009 2:27 PM
That doesn't sound right as thermocouples used correctly generally don't fail. Are you sure they are not suffering mechanical damage?
Are the thermocouples being subjected to vibration, bending or excessive handling?
If so then you need to either support them better or try a different type of temperature sensor such as an encapsulated or sleeved thermocouple, etc. The right sensor for the right application.
Good Answers: 109
Re: Thermocouple Life Span
10/02/2009 3:23 AM
Glass is very corrosive at these temperatures so you should use the correct tubing - I would try aluminum-nitride.
Any metal (including platinum) will go into solution either as oxide or as nanodispersed metallic clusters of a few 100 to 10000 atoms per cluster or as solid solution of metals in glass.
RHABE
United Kingdom - Member - Hearts of Oak Popular Science - Paleontology - New Member Engineering Fields - Mechanical Engineering - New Member
Good Answers: 75
10/02/2009 4:07 AM
Talk to your thermocouple supplier...either their products aren't performing as they should, or you're using the wrong product for that application. They will be able to advise.
Then contact a couple of other suppliers and check the answers
I have used:
TC-Direct: their K-type t/c lasted for 3 - 4 years underneath buses (we fitted them as a stop gap!)
Watlow: High tech automotive grade t/c used in our production products.
You don't say where you are, so there's a UK and a US supplier there.
Good luck
Chaos always wins because it's better organised.
Hobbies - CNC - New Member Hobbies - Musician - New Member
10/02/2009 4:24 AM
Type B: Platinum-Rhodium(30%) At 1000 deg C 9uV/deg C change
Continuous use +100 to +1600 deg C
Short term +50 to +1750 deg C
BS4937 part 7, ANSI/MC96.1 type B, DIN IEC B8, NF C42-321, JISC 1602
It would certainally apeare you are using the right type of thermocouple. The problem may be elseware as others have suggested. A higher rating type would be W (Tungsten) Up to +2600 deg C The change in voltage would be 20uV/deg C @ 1000 Deg C
Ive being using type K in a heat exchanger at 360 deg C for 10 years, no problim yet.
Think and move like an electron
10/02/2009 8:20 AM
Many manufactures make TCs to withstand the temperature that you are working at... (cutting costs)... We had TC type K... that where lasting 6 to 12 months....
We then changed suppliers.. now using Endress Hauser ... Our TCs have been in service for 3 years running working with a temperature of 950ºC 24 hrs per day 365 days a year.
10/02/2009 8:32 AM
I have used for more than 25 years thermocouple in glass processing and melting. You need to know glass chemistry if your thermocouple is expoused to the glass vapor.
The life goes to more than 5 years since I have one which has not moved a 1C in 5.3 years if you can take care of protecting your thermocouple tip from glass vapor and furnace contamiantion.
If you need further help I can send you drawing and design how to do that
Masyood
10/03/2009 6:04 AM
Got some insight there guys. Masyood, I will be very gratefull if you can provide me with the drawings.
10/03/2009 7:50 AM
If I have email will do that. I do not think you need this type of information in public domain.
you can always send email since I have business and may take few days to send that
Masyood
Hobbies - Musician - Tube Amps Only Please!
10/20/2009 11:57 PM
It should be in the manufacturer spec or call them up.
Regards, Maveric Manic - 'Knowledge is Power and Wisdom is knowing how to use it'
Register to Reply 10 comments
Anonymous Poster (1); Bricktop (1); English Rose (1); jack of all trades (1); madness (1); Masyood (2); maveric_manic (1); RHABE (1); signal (1)
