Previous in Forum: sintered oil impregnated spherical bronze bearings   Next in Forum: Power Generation, How Does it Work
power factor
10/04/2009 7:44 AM
How will work the diesel generator set as per power factor?
Re: power factor
10/04/2009 11:27 AM
You need to re-word your question. I do not understand what your are asking.
Re: power factor
10/04/2009 9:02 PM
There is no such things as "How will work the diesel generator set as per power factor?" The generator is just generated electricity an it has nothing to do with power factor.
Would it be" how the power factor works in the generator set?"
Re: power factor
10/05/2009 2:55 PM
power factor in inversely proportional to the generator which genrator electricity
Good Answers: 170
Re: power factor
10/07/2009 11:29 AM
The DG Set is normally rated in kVA. But, your loads are rated in kW. With the power factor, you can calculate the maximum kW that can be connected to the DG Set. (kW = kVA x power factor).
Re: power factor
10/12/2009 10:11 PM
Please restate the question. everyone is guessing what you are asking
Anonymous Poster (1); electricalexpert65 (1); georgesturge@nl.rogers.co (1); Simon Wan (1); wareagle (1)
