This is such a basic question that I'm embarrassed to ask, but I searched the web but couldn't find an explanation. So here goes:
I understand that a wire cutting across a magnetic field will generate a voltage. The magnetic field can be a permanent magnet or an electromagnet. If you were to rotate a rotor in an electromagnet, you would not get any voltage as long as the field coil was deactivated. The field coil must have voltage for a generator to work; right? So far, I understand how it works. How do you initiate a field without a source of power to begin with? A battery will work, but it will run down and the field will stop. How did the first power generation station get going?
