Previous in Forum: Power Generation, How Does it Work   Next in Forum: HVAC Calculations
Thunder, Lightning and LT ACB Trip
10/04/2009 7:59 PM
Hi All,
Lately i hv encounted a problems which during heavy thunder lightning with storm caused some of my LT (415V phase 50Hz) 4000 AMP ACB tripped and also caused some of the in operating air compressors and blowers trip.We have many LT main switch boards and air compressors and blowers as install at various location of factory.
What is the possible caused ? our earth chamber and impedance are in good condition
Regards
Re: Thunder lightning caused LT ACB trip
10/04/2009 8:53 PM
Your earth chamber and impedance is in good condition is another story. What about your factory roof lighting earthing chamber?
Do your factory had a lighting strike earthing chamber and where, which location do you earth your factory lighting strike earth chamber?.
Re: Thunder, Lightning and LT ACB Trip
10/05/2009 11:58 PM
Without knowing a lot more details, it sounds to me as though your circuit breakers did exactly what they were intended to do!
10/06/2009 4:35 PM
Check the lightning protection system installed in the factory. Adding a Voltage Surge Divertor to the incomer of the Main LT Panel will make a difference
10/07/2009 6:16 AM
Eventhough your earthing and impedance are good,but you need to check the bonding among those grounding chamber.
The cause of the promblem are from "Different Voltage Potential"between grounding point.
You need to make sure that all the earthing chamber are bonding together by the ground wire that are buried under ground.
Good Answers: 170
10/07/2009 11:26 AM
On what fault the LV ACB tripped? If you have a micro-processor based protection release in the ACB, there might be a possibility of earth fault trip. Pl. confirm.
dkwarner (1); electricalexpert65 (1); expthailand (1); kalliani (1); Simon Wan (1)
