Previous in Forum: rac   Next in Forum: Pigging Technology
Shaft Seal Selection
10/05/2009 10:22 AM
Dear colleagues
I want to do engineering evaluation to select oil seal for cooling tower gearbox working in hot & dusty environment.
The seals recently are failing frequently and gives life less than 3 years.
shaft seals we are intending to use is clark seals.I want to know the factors to consider in doing such evaluation to give us more operating life in dusty environment which can damage the seals because of contamination.
Good Answers: 120
Re: Shaft Seal Selection
10/05/2009 10:40 PM
The best people for this question are the Clark Seal people, and their competitors. They will have seen all manner of situations and can suggest the best choice.
As they say, the wheel has been invented ages ago, so have seals. It is a mature technology, rely on their expertise.
Per Ardua Ad Astra
10/05/2009 11:48 PM
Hi
The life of three years is good enough. You did not mentioned the rpm. running hrs per day.
Please call the seal people , have detailed analysis and paste the report here .
As per API682,Indented seal life should be 3 years( Continious Operation).
Hence do not worry much.
Be Happy.
Regards
Mahipal
0091-9871924734
10/06/2009 12:21 AM
'Bearing Isolator' gives best result.
Many standard manufactures are there, web search could help.
Try: http://www.skf.com/portal/skf_us/home/products?contentId=344216&lang=en
Good Answers: 58
10/29/2009 11:15 PM
Three years is not good enough for me.
Do as yesyen suggests and look at bearing isolators rather than lip seals. There are many good ones on the market, you need to choose according to your needs. Ones that I like these days are Magtecta and Labtecta by AESSEAL - fit into the same space as your standard lip seal.
Register to Reply 4 comments
Anonymous Poster (1); aurizon (1); The Prof (1); yesyen (1)
