Previous in Forum: Differential protection Vs Restricated earth fault protection of Transformer   Next in Forum: Busbar Calculations
How test the Buchholz relay during the maintenance of transformer
10/08/2009 5:42 AM
Thanks
Pathfinder Tags: Buchholz relay
Re: How test the Buchholz relay during the maintenance of transformer
10/08/2009 10:17 AM
Just open the drain plug at the bottom of the relay,for oil draining ,same time one have to open the airplug given at the top of the relay.oil level inside the relay decreases which was full before.Alarm appears at one point n then trip command occurs......some contain test button which can be pressed for testing of the relay......
"Know something about everything and everything about something"
Good Answers: 170
10/08/2009 10:21 AM
We used to use a bicycle pump (hand-operated) to pump in air inside the buch-holz relay to test it.
07/29/2010 9:09 AM
We tried using a bicycle pump, the alarm goes on but tripping does not occur.
To test trip , we drain oil from the drain plug. - electrix
Register to Reply 3 comments
Anonymous Poster (1); electricalexpert65 (1); giri (1)
