Previous in Forum: How test the Buchholz relay during the maintenance of transformer   Next in Forum: HV Step Coil / Transformer for Electric Fence
Busbar Calculations
10/08/2009 1:06 PM
Min . cross sectional area required of busbar, depend upon short circuot current.
Ex. Short circuit current is -- 50KA
SHORT CIRCUIT DURATION :-- 1 SEC
final temp of busbarr in deg centrigate :-165deg.c
initial temp of busbar in deg.c : 65deg.c
cross sectional area of busbar how much??????
please give me a solution...
Good Answers: 11
Re: sFault level calculation for busbar to choose a cross sectional area.
10/08/2009 2:15 PM
Requires calculus to obtain exact solution, but approximate solution can be obtained as below.
Assume bus bar size and length.
Calculate resistance at some intermediate temperature.
Calculate watt-second (joule) loss.
Calculate weight of busbar.
Calculate temperature rise of busbar
10/08/2009 2:40 PM
The short rough answer is around 400mm2.
This is a VERY common question on CR4. See previous threads on CR4 for the theory and formulas on how to arrive at the final answer (don't just take my word for it).
Good Answers: 16
10/08/2009 5:41 PM
You may need to factor in corona effects for a clean scope, where the minimal is not always optimal.
De gustibus non est dispudandum.
10/09/2009 4:30 AM
i agree with Jack of all trades suggest try ABB CAT DOC software available free from ABB for electrical calculations and you need to do some home work AtLeast on your part.
crm
India - Member - New Member
Good Answers: 164
Re: Busbar Calculations
10/09/2009 12:25 AM
have you tried the Busbar Calculator from L M Photonics? here is a link :
http://busbar32.software.informer.com/
10/09/2009 6:18 AM
Congratulations. A direct hit on CR4's most popular topic after cable sizing (to which the answer is British Standard 7671).
http://cr4.globalspec.com/search/sitesearch?do=show&sort=textmatchrank&srch=busbar%20sizing&srchobjs=t%2Cc&fs=12&order=asc
08/11/2010 7:13 PM
You should contact a reputed busbar supplier.Books/cataloques might give guidelines but cannot be held responsible
pnaban
Register to Reply 7 comments
Anonymous Poster (1); Carl Pugh (1); jack of all trades (1); kvsridhar (1); pnaban (1); PWSlack (1); Tippycanoe (1)
