Previous in Forum: Digitize Textbooks?   Next in Forum: Putting a flexible joint in solid copper wire
16 comments
ASME SA-36
10/08/2009 9:35 PM
What is the contains of ASME SA-36.Can you give me any reference of it?As far as i know that is material specification for carbon steel.Im quite new in vessels fabrication and Im glad if you can help me.
=D
Re: ASME SA-36
10/08/2009 10:35 PM
Hi,
Here is the source:
ASME Specifications
Good Luck!
Good Answers: 68
Re: ASME SA-36
10/10/2009 3:59 AM
Hi lynlynch,
GA to you Sir.
A good answer in the very first post, well done.
It would make a change if all requests were so quickly dealt with?
Take care.
Good Answers: 68
Re: ASME SA-36
10/09/2009 11:29 PM
Hi hafizan,
I post some sites which give details on your request, you choose which ever you want to view..
  1. ASME (mechanical) Code Issues - MATERIAL SA3620 posts - 11 authors - Last post: 7 Nov 2006IS IT POSSIBLE TO MANUFACTURE AN ENTIRE VESSEL (SHELL AND HEADS)ACCORDING TO ASME VIII DIV I USING ASME SA36 MATERIAL? OR IT MAY BE USED ONLY FOR STRUCTURAL ...
    www.eng-tips.com/viewthread.cfm?qid=170151&page=
  2. [PDF] 166-30: Statistical Analysis of Steel FormabilityFile Format: PDF/Adobe Acrobat
Take care.
Re: ASME SA-36
04/14/2012 1:07 AM
we found a site sale a lot of asme standard,cheap than asme official,the site is www.standardshop.org
Re: ASME SA-36
10/10/2009 2:12 AM
try the matweb site. It lists most of the steels free. For your A36 this is the link
http://www.matweb.com/search/datasheet.aspx?matguid=d1844977c5c8440cb9a3a967f8909c3a&ckck=1
Hope it helps.
Re: ASME SA-36
10/13/2009 11:54 AM
Dear friend, I was seraching for ASTM A569 in site matweb, but it didn´t show anything. Please you could help about it?
Thanks in advance
George
Re: ASME SA-36
10/10/2009 3:12 AM
The material specification ASTM_A36 covers carbon steel shapes, plates, and bars of structural quality for use in riveted, bolted, or welded construction of bridges and buildings, and for general structural purposes.
So, we can use the plates of that material in atmospheric storage tanks, atmospheric pressure vessels, nonpressure parts of pressure vessels such as saddles, supports, ... etc. But in no way to use these plates in pressure parts of pressure vessels such shells, heads, .. etc.
Good Answers: 68
Re: ASME SA-36
10/10/2009 3:52 AM
Hello Abdel,
GA to you Sir.
For a good answer.
Take care.
Re: ASME SA-36
10/10/2009 3:40 AM
Dear friend,
Please refer ASME Section II A where mentioned contains in SA36 is as below.
Carbon-0.25-0.29%
Mn-0.8-1.2%
P-0.04%
S-0.05%
Si-0.4% Maximum
Cu-0.2%
it is carbon steel for general purpose the mechanical properties is as under.
Yeild Strength-36KSi
Ultimate Tensile Strength-58 to 80 KSi
Elongation-21%
With best regards,
Anil
Saharanpur-India
Mobile +919412231734
Anil
Good Answers: 68
Re: ASME SA-36
10/10/2009 4:12 AM
Hello akp lmp,
Just a note about you having put your mobile phone number in your post.
That and your address could possibly lead the not so caring of this world to search you out and spam you.
If you feel the need to give this kind of personal info' then it is completely safe if sent by PM. You have to be a Member first, but you are so there is no problems there.
If you want you can post Admin and they will remove it and you can resend leaving your personal details out. Admins address below.
http://cr4.globalspec.com/user/mail/addmessage?us=39
Just a kind note from (I like to think) a kind person. Always play safe!
Re: ASME SA-36
10/11/2009 8:56 PM
dear All,
Thanks for all the reply. So now i think my design for socket for steriliser is wrong.Can anyone advise what standard requirement for socket in pressure vessel (3 bar pressure)?Should it goes for SA 105??
=D
Re: ASME SA-36
10/13/2009 11:49 AM
Dear friends: Please ASTM A569 from matweb?
Thanks in advance..
Re: ASME SA-36
11/03/2009 7:12 AM
Please ASTM A569 from 4shared.com.
Matweb.com didn´t work....
Thanks in advance..
Re: ASME SA-36
11/03/2009 8:36 AM
Re: ASME SA-36
06/06/2014 5:44 AM
Hi all,
I'm a quite new in vessel fabrication. And today I see in the our owner's drawing a "Plate, ASME A36". What is ASME A36? Can you give me some reference of it, pls? Thanks all.
Register to Reply 16 comments
Abdel Halim Galala (1); akp_lmp (1); Anonymous Poster (4); babybear (4); georgeh (2); hafizan (1); jackchen (1); lyn (1); tdh3587 (1)
