Previous in Forum: steam turbine bearing metal temperature going high   Next in Forum: Oscillationg fan..
A hard pill to swallow? Why not swallow more.
10/11/2009 5:07 AM
As you must have guessed, this one's for the hydrodynamicists out there.
Let me start by saying, that of the medical people I've spoken to, none knew about this little trick of mine—discovered after a recent illness after which I was put on a regimen including some sizable (viz., supplement/vitamin) pills.
Well I found that even using water in copious amount, as likely as not one of those big pills would hang up (a hard gulp) in the upper throat, apparently getting turned askew like a poor kayak-er riding a fall/rapids.
So one day, throwing caution to the wind, I added the second of three pills scheduled for ingestion. When they both together went down smoothly without any hangup (and again...over a few days' trials), I next tried three (the limit).
If not easier, three went went down just as easily, and still without any difficulty as had been the case with just one.
No, there was no (unwitting or otherwise) compensatory addition of water—the same or less water being used, or needed—in fact not much more than a generous sip.
So my question is:
What answer can I give to others (health care workers or not) to explain this anti-intuitive phenomenon...where, as best as I can hypothesize, attempting to swallow multiple pills somehow causes them to align in streamline conformation as they make way towards the esophagus...even that pill which is the "leader" pill!
...uncanny
Good Answers: 50
Re: A hard pill to swallow? Why not swallow more.
10/11/2009 6:10 AM
Actually, you were traumatized by your mother regarding the swallowing of gum. This was stored in your subconscious as "don't swallow anything that isn't food!"
When you swallow a single pill it feels like you're swallowing gum. When you swallow all three, you're tricking your mind into thinking that the mouthful must be food. QED.
That will be $145.00 - See my receptionist to set up your next visit in two weeks.
10/11/2009 11:11 AM
I'd keep this to myself, if I were you. No, It's too late. You've already spilled your guts to vermin and we all know he can't keep a secret. After all, he's just a cheap, for California, ($145.00 per session) shrink/vermin.
I wouldn't take the cosmic alignment theory public either. It's hard to imagine the little guys lining themselves upon the back of your tongue for the drop into the gut.
At least you were clever enough to use a fake name, "guest ". I hope you didn't give vermin your real name.
There could be a book here. "How I learned to swallow pills like a real man"
Good Answers: 123
10/11/2009 8:35 PM
Just promise her earrings.
Bob
Good Answers: 38
10/12/2009 7:22 AM
Possibly it deals with how much your throat must constrict to grab the object to allow it to pass into your esophagus. A larger amount is easily detected by it's mass alone. If not well chewed it is felt as a hard object and makes swallowing more difficult. I think the brain is used to what does and does not go down easily and adjusts for it. Small hard objects require more concentration to get by just as much as small apples swallowed whole.
The last fight was my fault. My wife asked "What's on the TV?" I said "Dust!"
bob c (1); charsley99 (1); lyn (1); vermin (1)
