Previous in Forum: Hyd. winch   Next in Forum: Question on boiler
Dynamic Deflection Formula
10/14/2009 3:36 AM
Can any one explain me the dynamic deflection formula for Stack =L^5*Vc²*0.00243/(W*Dl*Dr)*(1E-6) as per Kanti K Mahajan
what are its units?
"My Lord! truly, I'm in need of whatever good that You bestow on me!". Static Eqyuipment Design Engineer
Re: Dynamic deflection formula for Stack
10/14/2009 3:45 AM
You probably need to give us a hint of context.
'Stack' has a multitude of meanings..
10/14/2009 4:17 AM
In pv elite software calculations for dynamic deflection is performed bu using this formula
Ds = Maximum dynamic deflection of stack (at the Top)=L^5*Vc²*0.00243/(W*Dl*Dr)*(1E-6)
=720213366395mm
This evaluation is based on work by Kanti Mahajan and Ed Zorilla
which seams to be incorrect
Ds = Static Deflection=Pc Dr (Le)4 (12)3 / 8 E I
1.24
in
31
mm
Other data is as given below
Stack inputs:
Stack material=
ASTM A36
L = Total height of the stack=
320
ft
97536
mm
Vw = Basic wind speed=
160.93
km/h
100
mph
t = Thickness of the top stack=
0.79
in
20
mm
IDt = Inside dia.of Top section of stack=
16.75
ft
IDb = Inside dia.of Bottom section of stack=
31
ft
O.T = Operating temperature of stack=
550
F
E = Modulus of elasticity of plate material @ O.T=
26750000
psi
@550F
Y = Yield stress of plate material @ O.T=
28450
psi
St = Tensile Strength @ O.T=
58000
psi
Sa = Allowable tensile Strength @ O.T=
17070
psi
r = Steel Density=
0.283
lb/in3
C = Corrosion allowance=
0.1181
in
3.0
mm
Ws = Total corroded stack Weight=
753056
lb
341522
kg
W = Total Stack Weight=
1171565
lb
531322
kg
Can any one give me the Kanti K Mahajan book reference, how he calculate the dynamic deflection
10/14/2009 4:23 AM
Ah, chimney stack!
Good Answers: 114
10/14/2009 11:19 AM
The dynamic deflection is due to vortex shedding, but I always designed stacks so that their first natural frequency occurred at low wind velocity, low enough for the pressure to be insignificant, and the second above the design velocity so I never really got into the actual deflection.
I don't recognize your formula, but it's a very long time since I did that kind of work.
I don't know if this will help with a separate verification
10/14/2009 11:09 PM
Dear All
My problem, how to calculate static deflection and dynamic deflection is solved
But I have a doubt in calculating natural frequency is solved but
T = Period of vibration (As per Esco)=1.648 (Le^2) / Dr E0.5
Le = Effective Length of stack=
304
Dr = Average internal dia. of top half of stack=
16.75
26750000
1.7534
sec
f = 1 / T = Natural frequency of stack vibration=
0.5703
cps
but natural frequency calculated by PV elite (by using some matrices) and Compress software (by using Raliegh's Method) comes to be .9998 or 1 Hz. and value calculated by me by using the above formula is .5703.
Please suggest me which value to be use
this vent stack is pass on using .5703 giving the deflection within limits
Re: Dynamic Deflection Formula
10/15/2009 12:01 AM
See the following file free download for Flare Stack Mechanical Design Calculations, including Static Deflection, Dynamic Deflection, Ovalling Vibration, ... etc.: Flare_Stack_Mechanical_Design_Calculations
10/15/2009 1:23 AM
Dynamic deflection = Static Deflection * Magnification factor (in inches or mm)
Static deflection: The computed dynamic loading is applied as a stagnant pressure to the stack. Assuming it to be a cantilever beam, amplitude at the top is approximated by :
Register to Reply 7 comments
Abdel Halim Galala (2); nhabibkhan (2); passingtongreen (1); user-deleted-1105 (2)
