Previous in Forum: Power Transformers and Partial Discharges   Next in Forum: Single-Phase to Three-Phase
Voltage Relays and Current Specs
10/14/2009 9:02 AM
For IDMT and DT relays how important is pickup / drop out current ratio. Also the same for voltage relays.
Are there any specification as per standards such as IEC, ANSI etc.
Hobbies - Hunting - Deer and Birds Hobbies - HAM Radio - Achieved Ham Radio license in 2008 Hobbies - Fishing - Fisherman United States - US - Statue of Liberty - Know freedom, no tyranny.  Know tyranny, no freedom. Hobbies - DIY Welding - Beginner
Good Answers: 19
Re: Current and voltage relays
10/14/2009 10:42 AM
Yes the ratio is important since it's an inverse relay, the trip time goes decreases when fault current increases.
Check ANSI 51.
There's a number of web sites with examples of IDMT and DT uses in the same application. Do your search on "IDMT ANSI 51" and check out the Engineering Tips hits.
Go green, use a solar powered light saber...
Hobbies - Musician - Tube Amps Only Please!
Re: Voltage Relays and Current Specs
10/15/2009 3:34 AM
A lot of times the relay in question specification will tell you the min/max voltage for activating the relay and working voltage of the contacts.
Regards, Maveric Manic - 'Knowledge is Power and Wisdom is knowing how to use it'
Register to Reply 2 comments
