Hi.
I was wondering how could I remove the drive bit from a 1hp suffolk punch engine? It is a centrifugal drive unit - Once the engine is fast enough, the bits attached rub against the side of the drive tube, and the blades start to rotate. I cannot think how to remove it, it doesn't look like there is a screw thread to put a puller on, but it could just be gunked up with mud etc. Also, there is what looks like a pin on it, but it doesn't go all the way through, one one side you see the head of it (it looks like a pin head) and there is nothing on the other side.
