Previous in Forum: Reciprocating Compressors   Next in Forum: Coefficient of Lift Confusion
Engineering Fields - Mechanical Engineering - New Member Technical Fields - Technical Writing - New Member
Good Answers: 21
Coke Drum Material
10/16/2009 2:27 AM
Dear All Participants
As you know the coke drums are one of the most important equipment of Delayed Coking Unit. For sure the cyclic heating and forced coling are affecting the drum shell material by cracking and bulging. What alloy material is supporting in the best condition this kind of problems in order to minimise cooling time and then increasing production cycle?
Thank you to all
Look over to the next challenge
Engineering Fields - Piping Design Engineering - New Member Engineering Fields - Mechanical Engineering - New Member
Good Answers: 27
Re: Coke Drum Material
10/16/2009 7:23 PM
Hello Aurel,
Syncrude or Suncor?
Although I'm at a loss to help you in this regard, I know of a company (not mine!) involved in in-situ weld-overlay. They've repaired and re-established the pressure boundaries of a number of coking drums with some quite exotic materials.
If this is something that might help, I can dig through my old records to see what I can find.
Best regards, HeviiGuy
Good Answers: 97
10/17/2009 2:40 AM
Inconel
Register to Reply 2 comments
You might be interested in: Drum Pulleys, Drum Heaters, Drum Pumps
