Previous in Forum: Coke Drum Material   Next in Forum: Hinges for Heavy Doors
13 comments
Coefficient of Lift Confusion
10/16/2009 3:18 AM
Hi, I am running some analysis on a 3D airfoil with 2 cases: Case 1: an airfoil of a known type and a defined length x Case 2: same airfoil scaled to 1/2 with the same defined length x After running both cases on Ansys, i am getting higher Coefficient of lift in cases 1 in comparison with case 2. Is this normal? i think it should be the opposite because of the higher aspect ratio in case 2.
WissamS
User-tagged by 2 users
Canada - Member - I am from Canada Eh' Engineering Fields - Mechanical Engineering - Condition Monitoring, Advanced Diagnostics and Engineering Services Engineering Fields - Aerospace Engineering - Aviation Aftermarket Services for Honeywell Aerospace
Re: Coefficient of Lift Confusion
10/16/2009 5:22 AM
Interesting....
Could it be due to the amount of induced drag? More details please...
Better to have loved and lost than spend the rest of your life with a psycho.
10/16/2009 8:02 AM
Ok what's confusing is that the 1/2 scaled wing has a higher aspect ratio. AR=S/C, where S is the wing span which is constant in my case and C is the chord of the airfoil where the chord C2(case 2) is half C1(Case 1). which implies that AR2 is bigger than AR1. It is known that higher aspect ratio wings have lower drag, which is completely the opposite of the simulation results i got.
WissamS
10/16/2009 9:13 AM
Is the chord line constant/wing tapered?
10/16/2009 9:15 AM
no it's not tapered
WissamS
10/16/2009 12:07 PM
Are you using a constant angle of attack? or changing it to obtain the max cL for each size airfoil?
Engineering Fields - Mechanical Engineering - New Member Engineering Fields - Marine Engineering - New Member Engineering Fields - Aerospace Engineering - Aeromarine Vehicle Engineer
10/16/2009 7:39 PM
From Lennon, Andy; Basics of R/C Model Aircraft Design, Practical Techniques for Building Better Models; Air Age Inc; Wilton, CT; 1996
The actual lift, total drag, and pitching moment of a wing depends on seven factors not directly related to its airfoil section. These are:
1. Speed - Lift, drag, and pitching moment are proportional to the square of the speed.
2. Wing Area - All three are proportional to wing area.
3. Wing Chord(s) - Pitching moment and Reynold number are proportional to chord.
4. Angle of Attack (AoA) - In the useful range of lift, from zero to just before stall, lift, profile drag and pitching moment increase as the AoA increases.
5. Aspect Ratio (AR) - All three are affected by aspect ratio.
6. Planform - i.e., straight, tapered, or elliptical. All impact lift, drag, and pitching moment.
7. Reynolds Number (Rn) - This reflects both speed and chord and is a measure of "scale effect."
The Reynolds number, Rn for an airfoil = Chord (in inches) x Velocity (in mph) x 780 (at sea level)
Based on what you have written so far, it doesn't appear to me that both cases are NOT dynamically similar.
10/17/2009 2:05 PM
What i understand is that when the chord changes, in my case C2 is half C1 i would have a different reynolds, thus resulting to a different speed. So i should recalculate the speed for Case 2???
10/17/2009 8:51 AM
See following link that has graph of Lift Coefficient to Angle of Attack for various Aspect Ratios. Please note for the same Angle of Attack the Wing Lift Coefficient is directly proportional to the Aspect Ratio
http://worldofaerospace.googlepages.com/How-Aspect-Ratio-Wing-Lift-RC-plane.htm
10/16/2009 12:40 PM
Same airspeed, case 1 and 2? Not altering dihedral angle?
10/17/2009 2:06 PM
Yes i did run the simulation with the same airspeed and there's no dihedral angle.
Good Answers: 247
10/17/2009 12:51 AM
I'd guess that the lower Reynolds number is affecting the lift of the shorter chord (higher aspect ratio) section adversely. Some sections are quite sensitive to Reynolds number, and for most sections there is some very low Reynolds number where lift can fall off dramatically. (I'd guess that Reynolds number would need to be below 1x106 to see this effect.)
If the aspect ratio of the shorter span section is already high (let's say 10) then I'd think that Reynolds effect would dominate.
It would be interesting to build models and see if the Ansys analysis is correct. It would also be interesting to model it in Fluent etc. to see if the results are the same.
10/17/2009 2:10 PM
Actually, this is what am doing. i've been working a lot so far with fluent6.3 and recently i switched to ansys fluent. I am trying to see how accurate is the software (numerical analysis) compared with experimental results.
10/17/2009 9:27 PM
no Kidding?
Register to Reply 13 comments
Anonymous Poster (1); Blink (1); Doorman (1); Gannet (2); The Green Bastard (3); wissam (3); WissamS (2)
