Previous in Forum: Welding Position Qualification Range   Next in Forum: Clamping Load in Transfer Moulds
16 comments
Location: Midwest United States, Evansville, Indiana 37 N, 87 W
Measuring Large Diameter Parts
10/16/2009 12:33 PM
I frequently inspect large diameter parts ranging from 75 to 300" in diameter. The micrometer i use for this is a spring loaded 2" travel Inside mic. head (starrett) w/ .0005" dial indicator built in. We have the micrometer head on one end and the end piece of an inside mic on the other. These 2 pieces are mounted in a piece of conduit (emt) with set screws. We then use a laser linear measuring machine set to our target measurement to set these micrometers. When I have to measure an i.d. over 100" the EMT conduit then has more bow than I want. I want to replace the EMT with something more suitable. I need a material that is not too expensive, lightweight and rigid so that a 200" length doesn't have more than say 1/2" sag when held on the ends. The I.D. needs to have 5/8 ID (or i can machine it in there) the OD approximately 1 1/8 to 1 3/4. It doesn't have to be a round extrusion, it can be any shape other than rectangular. Would fiberglass or carbon fiber be suitable? are there other materials or manufacturers of quality tools such as this? Thanks in advance!
Pathfinder Tags: measurement quality control
Good Answers: 101
Re: tech advances in Measurement of large diameters
10/16/2009 2:37 PM
I'd look into extruded aluminum. You can get just about any shape you want, and some are extremely rigid, and still lightweight enough to handled easily.
I have to plug Rexroth.
But many others are out there which are similar (if not identical for less ).
Good Answers: 58
10/16/2009 6:55 PM
This is going to be a good thread. At the lengths you are measuring, thermal expansion is going to be a factor to the measuring device construction. The heat from your hands can make a difference. Check the expansion of the aluminum. How about glass tube? Same question, though. Fiberglass or carbon fiber tube may be contenders. I remember my windsurfer mast being stiff, and it was very light.
mike k
10/16/2009 11:53 PM
Why not use a laser measuring device?
10/17/2009 8:24 AM
What I was suggesting was the use of a laser measuring device to do the actual measurement rather than for setting the target for the tool. A direct laser measurement would seem much more accurate than the micrometer set up.
/tb/
Good Answers: 97
10/17/2009 2:00 PM
Maybe portability or loss and damage are issues...
10/22/2009 3:17 PM
We have a laser tracker but the method we are using (setting large pin micrometers) is preferred over using lasers, it is far faster, cheaper and in my opinion...more trustworthy. We account for thermal expansion. We cannot use galvanized, zinc, lead, aluminum or other soft metals.
Good Answers: 247
Re: Measuring Large Diameter Parts
10/17/2009 1:06 AM
A thin wall 1 3/4 inch aluminum pipe would sag (under its own weight) less than 1/2 in 200." A Carbon fiber or fiberglass tube would work fine in this respect also. In each case, the larger the diameter and thinner the walls, the better.
I'd be somewhat concerned with humidity affecting length with the fiberglass, less concerned with the same effect in carbon fiber, but concerned about temperature with the aluminum. I would think it would be very difficult to get consistent, repeatable measurements to within .001"
Good Answers: 213
10/17/2009 1:08 AM
If you go to "Engineer's Edge" on the web, they have a number of quick, free calculators that can help you identify your requirements. For instance, with the dimensions you gave (5/8" ID x 1-3/4" OD, Round Tube), the moment of inertia (I) is 0.45957 in¨4, and the cross-sectional area is 2.40529 in¨2. Maximum deflection at the center of a simply-supported beam with uniform loading is given by y=%/384*(W*L¨3/EI), where W is the area times the length times the density of the material. We have reduced the problem to two unknowns- you want a material that will give you a ratio of density to Young's Modulus of 4.59e-9 (assuming we are working in inches, Young's Modulus in psi and density in pounds per inches¨3). If you can not find a material that meets this requirement, you can play around with moment of inertia for various cross-sectional areas (several options are provided on the Engineer's Edge) that could perhaps give you a ratio that would be doable with available materials. Or you could find an old copy of Roarke's Stress and Strain and look up the formulas from the myriad collection offered in this fine volume.
Good Answers: 97
10/17/2009 2:20 AM
I agree with post #1, I use AL extrusion or channel designed as edge trim or supports for large glass panels.
United States - Member - US Navy Veteran
Location: Nothing sucks more than that moment during an argument when you realize you're wrong.
Good Answers: 22
10/17/2009 8:34 PM
You can use an aircraft grade aluminum extrusion if the temperature is stable and you can be slightly off in your readings (a generous tolerance) otherwise you'll need to use carbon fiber but that will be expensive.
You never know when it will strike, but there comes a moment when you know that you just aren't going to do anything productive for the rest of the day.
Good Answers: 94
10/19/2009 5:40 AM
We've had a discussion about this topic in the past here. The comments in that post may be useful.
10/19/2009 6:14 AM
Why not use diameter tapes and forget about the unimportant details?
How can you be two places at once when you're actually nowhere at all?
Good Answers: 94
10/19/2009 6:26 AM
They're measuring inside, not easy with a tape.
10/19/2009 11:56 AM
Why not use a pi tape which measures the O.D. and subtract 2 metal thicknesses. Pi tapes can be made for any diameter.
Good Answers: 97
10/19/2009 2:51 PM
Diameters may have irregular surfaces...
10/24/2009 10:30 PM
I'd measure it vertically if possible .Straight up and down. But that's because I'm a straight up kind of guy.
Register to Reply 16 comments
Anonymous Poster (1); Blink (1); bwire (3); cwarner7_11 (1); Heart Cooks Brain (1); Jerry New Hampshire (1); markar (1); mike k (1); mtdmaker (1); Nigh (2); RVZ717 (1); Tom_Consulting (2)
