Previous in Forum: Measuring Large Diameter Parts   Next in Forum: Pneumatic Test with U-Tube Vertical Manometer
Clamping Load in Transfer Moulds
10/19/2009 7:44 PM
We want to buy a rubber transfer moulding machine to make a part whose area perpendicular to the direction of compression is about 28 square inches. I saw a formula for calculating clamping loads in injection moulding machines in this forum. Should the same formula be used for transfer moulding machines also? We have been offered a used machine with a clamping load of 35tons but want to make sure that the clamping load is enough. Thanks for your help
ranga
Re: clamping load in transfer moulds
10/19/2009 10:34 PM
If you apply the general rule of one ton (clamp pressure) per square inch (of part area), you should be fine.
you have 5/4 capacity. Watch your transfer speed.
The more viscous the material, the more clamp you need.
10/20/2009 6:11 AM
Lylynch.
Thanks a lot for the quick reply. Your reply to a previous email regarding clamping loads for injection moulds was very extensive and informative.
cheers
10/20/2009 11:37 PM
I would check with the material vendor for their recommendation. I have seen transfer molding cavity pressures exceeding 5000 psi. With 28 square inches you may need as much as 70 tons of clamping force. I would go to the source for an answer so critical for your success.
10/21/2009 6:25 AM
dadio926,
Thanks for the suggestion. Will check with the material supplier.
cheers
Register to Reply 4 comments
Anonymous Poster (1); Daddio926 (1); kuplix (1); lyn (1)
