Previous in Forum: Bush Material Question (En31)   Next in Forum: Book for Design Engineer
Belt Tension calculation?
01/01/2007 10:51 PM
How to calculate belt tension? and Could you explain the belt tension calculation using 4 pullys or example in vehicle engine pully and belt drive?.
Pathfinder Tags: belt tension calculation
United States - Member - Engineering Consultant Popular Science - Evolution - Understanding
Re: Belt Tension calculation?
01/02/2007 8:13 AM
You can't from the vague information you provided.
Assuming you mean V-Belts, (or any other kind) there is unlimited info on the web from manufacturers of belts, and other reliable sources.
One link you should find useful for V-belts:
http://www.alliedbearings.com/downloads/dayco_carlisle_tensioning.pdf
Safety - ESD - RF Manufacturing ESD Installer
01/03/2007 6:22 AM
I had to save that document. Thank you Greg G.
“The problems we face cannot be solved with the same level of thinking we had when they were created” Albert Einstein
01/03/2007 8:51 AM
The Belt tension calculation is a product of the amount of wrap and the amount of power consumed by the accessory being driven.
You want enough wrap and tension to drive the accessory with out slip, but you don't want to exceed the load that the accessory bearings can handle.
There is also harmonics involved the the power pulsations from the drive motor and the inertia's in the rotating mases in the accessory.
That being said you cam calculate the tension required with a proper belt routing, power input and frequency pulsations, load and inertias of the accessory's, maximum RPM of the accessory's, etc.
There are manual calculations also programs to calculate.
Proper calculations would save allot of headaches.
Rob
www.blackracingdesigns.com
Anonymous Poster (1); Greg G (1); jowens (1)
