Previous in Forum: Gearing Motors   Next in Forum: Belt Tension calculation?
12 comments
Bush Material Question (En31)
01/01/2007 2:43 AM
MHi,
In general, En31 is used as bush material.
I just want to know the material superior than En31
How about using En353 and 20MnCr5
Wishing a Happy New Year to all members
Best regards
jk
Good Answers: 247
Re: Bush Material Question (En31)
01/01/2007 11:39 PM
Bush material? One part village idiot, one part megalomaniac...
Sorry.
01/02/2007 6:12 AM
Ad-hominem doesn't become you. Apology accepted.
(it is lightly amusing)
See Bio for signature line........political correctness and insecure people are such a pain-in-the-ass.
01/02/2007 8:41 AM
Let's try to keep the CR4 dialog slightly above the Rosie Odonnell level.
Popular Science - Weaponology - I AM IMMORTAl UNTIL I DIE! South Africa - Member - New Member
01/02/2007 9:39 AM
Now now Ken, haven't you heard that a pre requisite of becoming an engineer is that you are not allowed to have a sense of humour! I did rather enjoy the comment though (please don't tell my chief). I seem to remeber a comment made in an official report by an officer concerning one of his subordinates during WW 2 and I quote.."This man is depriving a village of an idiot!"
Life is much too serious to be taken seriously.
United States - Member - New Member Engineering Fields - Chemical Engineering - New Member Hobbies - Musician - New Member
01/02/2007 6:50 AM
Maybe English is not your primary language. I think you may mean BRUSH material not BUSH material. There is a lot of difference!
"Blessed is the man who, having nothing to say, abstains from giving us wordy evidence of the fact." George Eliot [Mary Ann Evans] (1819-1880)
01/02/2007 8:02 AM
Hi milky
En31 grade is used for making Bushes in jigs.
En353 and 20MnCr5 are case hardening steels.Definitley these two will give a better life.
Lubrication and surface roughness are also matters a lot.
Robert
01/02/2007 8:41 AM
Hi jk,
I feel that you should use OHNS ie OIL HARDENED NON SHRINKABLE STEEL.
I have experienced better life and better wear resistance and better surface finish with this material. This is through hardening steel.
Hope you will find better results.
Limbkar
01/02/2007 6:49 PM
YOU SHOULD STINK to the original bush material
as a harder material will wear the shaft instead of the bush
so dont be the village idiot
01/02/2007 9:39 AM
Hi JK,
Please tell what is the hardness of the bush and where exactly it is used, mention its size like Outer / Inner Diameter & length & unit of measurement.
If you cannot mention where it is used, just simulate it to a nearest example and reply, so that i can suggest you the right material.
With regards
Yatish
01/02/2007 12:13 PM
If you had described your application with a little more background--- saying "Bushes for use in Stamping Dies,in Closed-Dies for forging,in Jigs" etc., comment like #2,#3 etc could have been avoided.
If these are indeed your applications, Tool and Die Steel Tables tell all. Or in British Standards(EN Steels)
If you wanted Bearing bushes--you needed Bronzes, Sintered or alloyed. Certainly not heat treatable Hi C, Hi Cr steels.
01/02/2007 11:48 PM
Yes you are right sir, We can use HcHcr steel for bushes.
"Let my body and its pain take care of each other, thou my mind will always be in a bliss"
01/03/2007 4:58 AM
Sreedhar you got me totally confused-YES or NO?
Anonymous Poster (5); Blink (1); mikey (1); mongoose (1); MUKULMAHANT (2); sridharyaamunan (1); water buffalo (1)
