Re: how to design a propagation area in plant nursery
10/18/2009 2:34 AM
You'll need to know the temperature and relative humidity (RH) of your propagation area to do this. Refer to a psychrometric chart and see what is the total mass of water vapor that the volume of air in your propagation area can carry. From the RH value on the chart, see how much more moisture the air can take up until the RH reaches 100%: that would be the evaporative capacity of your air.
You'll need to refer to your local codes-of-practice for the ventilation criteria, and size the fan accordingly. Without more details this is about the best information anyone can provide you.
