Previous in Forum: mccb   Next in Forum: Earthing Question
Auto Transformer Rating
10/20/2009 11:43 PM
Dear All,
i need your help to decide the rating of three-phase autotransformer for below mentioned loads,
Supply voltage : 3-phase+N, 415V.
Basic M/C Load : 3-phase, 415V, 3.42kW
Device Ratings (kw) phase
Heaters Zone-1 2.3 3phase,415V
Heaters Zone-2 0.6 3phase,415V
power supply 0.12 2phase,415V
Inverter 0.4 3phase,415V
Total load(kw) 3.42
Optional M/C load : 1-phase, 230V,
Trimming unit 0.66 single phase,230V
blower 2 single phase,230V
Total Load(kW) 2.66
Total Machine Load= Basic machine + Optional units
=3.42+2.66
=6.08kW
incomming only 3-phase,3-wire system with no neutral.
secondary is star connected 3-phase,4 wire system with autotransformer star point as neutral.
what will be the effect of unbalanced load and neutral floating on loads?
For this machine i require two Autotransformers one is only for basic M/C load(3.42kW,3-phase,415V) and the other is for basic M/C with optional M/C loads(3.42kW,3-phase,415V, + 2.66kW,1-phase,230V).
Autotransformer tapings: -20V, 0V, 20V, 200,230,400V, 460V, 550V, 600V
i kindly request you to please send the required ratings of Autotransformers for both the machines.
Good Answers: 11
Re: Auto Transformer Rating
10/21/2009 1:25 PM
It is dangerous to use an autotransformer in this application.
Should use single phase isolation transformer for single phase loads.
10/21/2009 11:03 PM
Dear Carl,
thank you for your feedback.
we are using autotransformer only for m/c which are export to other countries where there is 3-phase supply voltage is other than 415V. In this case if we need to give two seperate transformer for the machine then cost of the m/c will go up.what will be the cost effective solution for this application?
10/22/2009 11:17 PM
Dear Carl,
11/01/2009 9:52 PM
any new solutions .......?
Register to Reply 4 comments
