Previous in Forum: Magnetic Amplifiers   Next in Forum: Solar Refrigerators
Canada - Member -  Member
Location: Hamburg NY (just south of buffalo) pre-Hamburg(1998) home was the Yukon territory of Canada
Good Answers: 27
Euoropean Lamps
01/05/2007 7:47 AM
I need to find a distributor for HORIZONT (German) traffic safety lights. Specifically replacement bulbs. I need a 6v 20w (halogen?) bulb with a single contact bayonet base. the lamp is marked HORIZONT 6v 20w. Their web site was of no assistance.
Any help is welcome.Thanks
Nothing is fool-proof to a talented fool
Re: Euoropean Lamps
01/06/2007 6:07 PM
We need some physical dimensions as well Guy.......!!!!! Guessing will not help!!!
Good Answers: 27
Re: Euoropean Lamps
01/09/2007 7:32 AM
The bulb has an S-8 base (same as wagner 1156) the halogen lamp itself is 3/4 inch in height above base and 5/8 inch across. hope this helps, Thanks Lonnie
Re: Euoropean Lamps
01/12/2007 10:15 AM
What is the base diameter? Are the Bayonet pins at 180° to each other? Are they at the same height relative to each other? What is the overall height of the lamp from top to bottom?
Register to Reply 3 comments
You might be interested in: Halogen Lamps, Lamps, LED Lamps
